I need to do industrial black ano with no finish requirements. What I mean is I will be anodizing half inch square bars with threaded holes.
The bars need no polishing/blasting/ or sanding. They just need to be black. Can I just degrease - WB test - DE-oxidize then anodize? Every one the fourm seems to be having GREAT results with parts that are pre-treated to some degree. I am very impressed with the level of sofistication in here. I hope to be able to contribute myself after some time. Thanks |
Yep... that's pretty much it. You can skip the de-ox too if they are freshly machined parts (de-ox will dull it just a bit).
thanks for the response.
I am not sure, do you realize the bars are not machined on sides. they are half inch squares, cut to length, then drilled. So i don't have to remove the ink printed on the side either? |
I would de-grease/remove ink with lacquer thinner, blow dry, then go to the SP degreaser to pass water break, then de-ox, then ano normally.
That may sound kind of wierd, but if there is any grease or oil, you don't want that going into the de-ox.
Etching the parts in a sodium hydroxide (lye) solution after the degrease/cleaner and before the de-ox step may be beneficial in giving a more even and consistent color and appearance. Mill finished aluminum can vary greatly in the oxide layer which will be present, and in my opinion a sodium hydroxide etch is vastly superior to a sulfuric/ferric acid based de-ox solution in removing aluminum oxide.
thanks M_D. That sounds alot simpler and less handwork. I would assume etching the parts would sorta ensure WB will pass.
Would you agree? I will search the fourms for a starting point of mixture for the lye. |
Yes, I agree... etch step will ensure a uniform surface.
So... lacquer thinner to remove ink/grease/oil, etch, de-smut/de-ox, ano. No need to de-grease after de-smut as long as the parts are not handled with bare hands, and they pass WB. Etch solution: 1 can (16oz?) Red Devil lye into 3gal water (no more than 70F).
| Weber 40 IDL die cast body finish | miura | Other Metal Finishing Questions | 7 | 01-31-2008 11:12 AM |
| Golf Clubs - How to remove nickel finish prior to refinishin | doctordave | Other Metal Finishing Questions | 3 | 06-03-2005 03:21 PM |
| Newbie, trying to find best way to finish aluminum-LONG POST | chik | Metal Polishing Questions | 6 | 03-14-2005 08:11 PM |
| can we identify this finish? | funkmunky | Electroplating Questions | 3 | 12-15-2004 08:45 PM |
| Mill Finish Brass-How do I polish? | BrassLover | Metal Polishing Questions | 0 | 05-02-2004 12:49 PM |
