Old 10-05-2006, 09:31 PM
Analog_Music is on a distinguished road
Default Selecting power supply
Hi, I'm new to the board. This is a great site, the most amount of useful material I've found on anodizing thus far, thank you very much! I'm working on a large anodizing machine for my college and would appreciate it if you folks could help me out on the way.
This page is confusing me... http://www.caswellplating.com/kits/rect.htm
Are the platers and rectifiers the same thing? What is the difference? I will need approximately 25 amps as my anodizing job is 600 square inches.
Would the rect25 be good for this?
thanks in advance!
Jonathan
Old 10-05-2006, 10:09 PM
sswee's Avatar
Moderator
Default Re: Selecting power supply
Welcome,
Are the platers and the rectifiers the same thing? Yes and No. They both convert AC to DC. The plating rectifiers work in constant voltage mode only. They are not good for anodizing due to this and their limited voltage output. You will need a power supply that works in CC/CV (constant current/ constant voltage) and for a 6ASF CD at least 18V to be on the safe side. If you have a part with 600" square SA, you can drop to a 4.5 to 5.0 CD and get by with a 20A PS. It will just take a little longer to do the same thickness coating.
SS
Old 10-07-2006, 12:31 PM
Thefool is on a distinguished road
as sswee said basically anything would work to a certain extent, it would just take longer. I may have a 20 amp/20 volt or a 30 amp/60 volt cc/cv power supply that i might be able to sell if need be.
Building power supply from manual dfarning Other Metal Finishing Questions 0 02-19-2006 11:56 AM
power supply Techno Electroplating Questions 0 09-20-2005 08:58 PM
anno power supply jasonboulanger Anodizing Questions 2 01-07-2005 05:48 PM
Power supply aalamo Electroplating Questions 5 11-24-2004 09:21 AM
Anodizing Power Supply Q's jnbsystems Anodizing Questions 7 10-02-2003 10:33 PM
