Old 10-08-2006, 04:22 PM
blewis999 is on a distinguished road
Default I don't get it
I am on my second batch. This is fun. But I thought the voltage (as read on my cc/cv display should increase as time goes on.
My first batch was 41in^2 set to 1.7A for 120min. Voltage started around 16V then fell as time went on. ended around 14.5 or something.
Parts turned out great.
Second batch : 71 in^2 set to 3A for 120 min. Valtage started at 15.1 Now half way through it is 13.9.
Am I thinking backwards?
Old 10-08-2006, 04:28 PM
Default Re: I don't get it
Different alloys do different things... are they all the same?
Old 10-08-2006, 04:34 PM
all 6061-t651 or t65
Old 10-08-2006, 08:33 PM
How about temperature and agitation?
Yes, with 6xxx alloy, the volts should go up, but remember, the lower the temperature, the higher the volts (and vise-versa). As the temperature rises, the volts will go down. Try to keep the temperature between 68F and 70F, and use good agitation.
Are you taking notes?
I always chart the progress of each run.
Write down your start and end times, along with the calculated amps.
Note the temperature and volts at regular intervals: start, 15min, 30min, 45min, etc.
It will help you a lot when trying to diagnose problems.
