Old 11-15-2006, 04:16 PM
hurricaneracing is on a distinguished road
Default Water cycling
If I were to use permanent rinse tubs what type of filter system would you recommend for the rinse tubs. I would like to get where I dont have to drain and fill them everytime I run a batch. I sure the dye rinse will need changed but what about the rest?
Old 11-15-2006, 06:39 PM
Default Re: Water cycling
I've heard that guys will run RO water constantly into the final rinse tank. They are also using two tanks... first rinse and second rinse. It seems that you could run the RO water into the final tank, with run off going to the first rinse, then into the drain.
The thing is, filters are not going to remove the drag-off. You'll need to replenish the water to control that.
Personally, I have a 55gal tank with an auto fill float valve from the RO filters, and a large ball valve to fill individual tanks. Takes maybe 5 seconds to fill a 3gal bucket, and I use a seperate rinse bucket for each process.
Old 11-15-2006, 08:12 PM
I like the float idea. If I run a drain is there any enviromental issues? Right now I take small quanities to work and dump it in a large recycling system. I dont want to have to transport too large of containers though.
Old 11-15-2006, 09:29 PM
Well... I always spray/mist the parts into thier original tanks before dunking them, so there is very little drag-off. Since I'm doing small batches, and dispose the rinse water after just one use, there is no concern with dumping down the sanitary sewer.
If you're concerned with contaminant levels of the rinse water, you should inquire what levels are acceptable.
Distilled Water? machinist_1 Anodizing Questions 2 06-08-2005 07:23 PM
dammage from water? kickn Anodizing Questions 1 11-29-2004 10:10 PM
Distilled Water vs DI Water mcgoo49 Other Metal Finishing Questions 0 03-02-2004 08:20 PM
RODI water storage Easttex Anodizing Questions 6 12-01-2003 01:20 AM
distilled water?? scopenut Electroplating Questions 10 06-08-2003 10:24 PM
