I just mixed up some black dye last night and gave it a test run. I always check all of my parameters temp, volts, amps and record the data. What I was shooting for was 1 mil thickness at 6ASF. Well after ~15 min in the dye I pulled out the part and I thought it was the nicest looking thing I have ever seen in my life. When I sealed it I got a lot of dye bleeding out and it was a reddish-brown color.
Well I looked everthing over and found out that I am retarded and mis-calculated the surface area and when I plugged in the correct numbers in I found that it would have only produced an anodize layer of ~.8mils So my question is, given my situation does it appear that my problem was a result of the thinner anodize layer or is there something else that I may be missing? |
Greetings,
hummmmm . . . . . . I would not make such a conclusion so quickly about your brownish black dye result. Acidrain is right but maybe there is something else here . . . . . Certainly pore structure is critical in the dying process, but how does a thickness of .8 make any difference from a thickness of .2 so far as "dye leeching out" . . . . . . and resulting brownish tint ? Researching many archive posts, I must say that there could be a couple of issues in cohorts to negatively affect your final result. 1. Black dye PH is important. --- check archived threads to capture this significance. MD,Neomoses will produce some good analysis. 2. Substrate category ---- 6061 vs 7075 vs 2024 vs . . . . on & on but it is important. 2024 & 6061 in same tank, same LCD parms --- very different in black "depth" after a successful process. 3. Check all categories of your process --- something is amiss. A parameter or set of parameters is not building a bridge successfully to your next process. This seems like a very nice return for the investigative effort. I wouldn't hesitate to review and step through this particular Ano run. The ability to intuitively understand the interelationships of all the variables in the anodizing process is in this type of circumstance. archi |
| Black anodize dye doesn't take | AlanJB | Anodizing Questions | 1 | 09-18-2006 11:19 PM |
| Anyone done acid washes? | scamihorn | Anodizing Questions | 34 | 06-08-2006 02:59 AM |
| 7000 series parts dye, but 6000 series won't | acidrain | Anodizing Questions | 20 | 11-17-2005 11:19 PM |
| black dye problem | destroyer125 | Anodizing Questions | 5 | 09-09-2005 05:23 PM |
