Old 02-23-2003, 10:41 AM
tool_man
Send a message via MSN to tool_man
Default Low temp. anodize sealant
Has anyone used the new,low temperature anodize sealant.I would like to know how well it works in comparison to regular sealant.
Old 03-10-2003, 01:01 PM
NeoMoses
I am also interested in this. How warm is "lukewarm." I have heard conflicting stories. in the rec.crafts.metalworking newsgroup, I was told that one would have to hold this at 190F for sealing, which seems far from lukewarm in my opinion.
In order to buy a new chemical, it would have to be much easier to use than boiling water, faster, or produce more consistent colors.
Old 03-12-2003, 08:07 PM
erogers
NeoMoses,
Nickel acetate (anodize sealer)is available in 2 flavors that I know of. One has to be heated to boil or all most boiling, and the low temp, which works around 90 degrees. Anodize sealer is faster and easier that boiling water or steam. The 190 deg mentioned in alt.rec.metalworking is that standard sealant.
Oven temp vs part temp getastro Powder Coating Questions 4 10-01-2007 12:53 AM
LCD anodize of a large piece? scocklin Anodizing Questions 2 12-29-2004 12:21 AM
IR Temp Probes getastro Powder Coating Questions 3 07-21-2004 09:12 AM
Can I use VHT high Temp with Krylon High temp radiator paint magnus Other Metal Finishing Questions 1 05-03-2003 11:20 AM
Basic anodize questions erogers Anodizing Questions 0 03-12-2003 07:54 PM
