+ Reply to Thread
Results 1 to 4 of 4
Thread: anno question????????
  1. #1
    Default anno question????????
    My buddy tried to anno some test pieces...he used some cocker parts that he had around to practice...they were anno'ed for about 2 hours...then dyed in the caswell blk dye and sealed with the chem sealer!
    but the pieces went into the anno process shinny and have come out of the coloring phase very dull!? any ideas?
    thanks
    Paul
    Share with Facebook
  2. #2
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,283
    Default Re: anno question????????
    Some detailed specs on the parameters of the run will help diagnose a problem.
    SS
    Share with Facebook
  3. #3
    cocker back block about...1 by 3 inch by 2 inch...in the anno bath for 3hrs about 10 amps....my budy hand pollished with a cloth no polish! and it buffed out blk....he did not use the de smut!
    what do you think!
    paul
    Share with Facebook
  4. #4
    Join Date
    Nov 2004
    Location
    Posts
    1,283
    A block 1x3x2 is about 22" SA. 10 amps on 22 square inches of the part is about a 65.5 amp current density. If you could anodize at that rate, it would only take approximately 11 minutes to grow a 1 mil coating. Something isn't right with your calculations, method or measurements.
    What kind of power supply are you using?
    Do you use the 720 rule?
    Do you check the tank temp before or during a run?
    Do you have tank agitation?
    What acid ratio are you using?
    SS
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. powder coat removal question
    By eliasson in forum Powder Coating Questions
    Last Post: 04-20-2007, 08:28 AM
  2. Newbie question about coverage
    By ublinkd in forum Powder Coating Questions
    Last Post: 03-05-2007, 12:00 PM
  3. Nickle "Plug-N-Plate" question HELP!!
    By pyro1711 in forum Electroplating Questions
    Last Post: 08-03-2004, 09:29 PM
  4. Peak voltage question
    By mudwhump in forum Anodizing Questions
    Last Post: 01-14-2004, 10:53 PM
  5. Brand Newbie Aluminum Polishing Question
    By gdsegel in forum Metal Polishing Questions
    Last Post: 04-25-2003, 08:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
