Old 02-03-2007, 10:10 PM
Animal is on a distinguished road
Default question
For you Guru's
im using a constant current 5 amp power supply i purchased from Caswell.
When Anodizing 6061 T6 Aluminum the "volt" meter will climb upwerds of 14 volts no problem.
When Anodizing 2024 T351 Aluminum the "volt" meter will max out around 9.2 volts.
is this normal? why wouldnt the 2024 voltage climb as high as the 6061?
Old 02-04-2007, 01:21 AM
cprocess is an unknown quantity at this point
Default Re: question
This is a normal observation. The reason for this voltage difference, is that the main alloying element in the 6061 alloy is silicone, while the main alloying element in 2024 is copper.
powder coat removal question eliasson Powder Coating Questions 29 04-20-2007 09:28 AM
Newbie question about coverage ublinkd Powder Coating Questions 4 03-05-2007 01:00 PM
One quick question about PC heat durability UnorthodoxCreations Powder Coating Questions 1 09-19-2005 02:07 AM
Peak voltage question mudwhump Anodizing Questions 6 01-14-2004 11:53 PM
Brand Newbie Aluminum Polishing Question gdsegel Metal Polishing Questions 1 04-25-2003 09:04 AM
