Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
  #11 (permalink)
Old 02-14-2007, 11:28 AM
dewil is on a distinguished road
Default Re: what went wrong?
Originally Posted by Tim Wiltse
Dewil,
No the part will only draw the amps it needs! If your charger puts out a max of lets say 6 amps the part may only draw 2 or 3 amps as it anodizes. If will not go and draw the full 6 amps the charger can do. This is more or less the old method of anodizing before Caswell starting only doing tech support on the LCD method.
Yup temps are very importand. If your anodizing tank is 10 degrees colder than what it should be you will see a very large drop in the amount of amps it draws. The lower the amps the longer it will take to anodize to the same given layer thickness.
LAter,
Tim
Hi Tim! Why does everyone talk about using controled power and constant current if it isnt needed for good results?
Im not questioning your knowledge itīs just that there is so many bids!
  #12 (permalink)
Old 02-15-2007, 12:33 AM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Tim is descibing the "let-er-fly" method. Caswell does not subscribe to that method, and neither do I.
Only with carfully controlled perameters can you expect repeatable results.
All of your tank temperatures are critical, especially the ano tank... just a couple of degrees one way or the other drastically changes the resistance. I suggest 68-70F.
I do things.
  #13 (permalink)
Old 02-15-2007, 04:44 AM
I have ordered a CC powersource now so I can have full control of the power. I had no idea that the bath-temp was so critical, it must have been way off since my line is in a pretty cold garage! Ill see if I can find some descent heaters!
Thanks
  #14 (permalink)
Old 02-17-2007, 01:01 AM
sswee's Avatar
Moderator
I run my tank at 60*F. The voltage demand is only slightly higher. Approximately 2V. Aquarium heaters work ok. The glass tube type.
SS
  #15 (permalink)
Old 02-17-2007, 07:55 AM
SS
thanks! Will look into it today when im getting food for my dog!
  #16 (permalink)
Old 02-26-2007, 04:12 AM
Thanks for all the tips you gave! It paid off!
I have invested in titanium wire and it saves me lots of time. I also have invested in a good thermometer so I acurately can read the temp in botch C and F.
I ran the stuff in room-temp and then in 140f dye and it was a night and day difference!
Another question: Why is there more or less activity at the anode from time to time? I ran the same cd and with one batch it bubbeled very visibly and with the other so little you hardly could see?
Today I should get my CC powersource and cant wait to try it out next weekend!
Here are some pics from the run this weekend, ised melting glue to mask some brass-bushings. Not the best since it melted when I sealed it afterwards... But you learn from your misstakes!
  #17 (permalink)
Old 02-26-2007, 10:10 AM
sswee's Avatar
Moderator
Looking good. The CC PS is going to make everything easier and give a better more consistant coating. Glad to see it coming together for you.
SS
  #18 (permalink)
Old 02-26-2007, 10:45 PM
acidrain's Avatar
Great job!
Don't get too caught up in why there are more bubbles sometimes... it's not a good indicator of consistancy.
I do things.
  #19 (permalink)
Old 02-27-2007, 03:35 AM
Thanks guys! I will add a gallery when I hav some things to show for!
Ill get back to you if I run in to more speedbumps!
  #20 (permalink)
Old 02-28-2007, 01:17 PM
rclint is an unknown quantity at this point
A good example here of these guys knowing what it takes
If you want to play, you gotta pay LOL
It's not much more cost for a regulated power supply, and you can monitor so many things, trouble shoot, and know when it's right. Also as Acidrain says the hang wires are always a good way to trouble shoot, however 2 things I see can cause this to give you a bit of a stray reading. 1 being the part being anodized if it is cast or not so good grade of aluminum, and 2 if you calculated the surface area wrong, still with the wires you can look and narrow down a lot of things
I have learned a lot here, lots of good folks
Clint
Closed Thread
Help, I'm doing spmething wrong autoshopowner Powder Coating Questions 3 11-08-2006 08:13 PM
Can you figure out what I did wrong? cruizer Powder Coating Questions 11 07-17-2006 04:34 PM
Cartridge rolls - description wrong? mpierich Caswell Please Sell This... 1 06-15-2005 12:52 AM
Ok,what am I doing wrong mach1man Metal Polishing Questions 1 08-18-2004 08:31 PM
What's wrong here...... dsacco1013 Powder Coating Questions 2 01-05-2004 11:15 PM
