Hello all!
I'm a Newbie here, just curious as to wether there are any cheap tubs or totes out there that can withstand the temperatures of boiling water and what you may have used for larger items, such as sheet metal aluminum panels? I am building a Kit car and it has a large number of aluminum panels that I want to coat, some are as large as 48" by 36" (the largest one) everything else would not be a problem, just wondering what some of you might suggest I use for a larger tank for anodizing. Thanks in advance! Ben |
Thanks everyone, This is only an idea, most of the panels I am going to do are 18" x 36" at the most, but I still need to find a container large enough for those. I will check into a tractor supply/farm supply outlet here in Missouri and try my luck.
Thanks again! Ben |
Ben |
I would probably keep my eyes open for a good DC stick or TIG welder. Stick welders and TIG welders use a CC power source, and many are rated for a couple hundred amps at 20 Volts or greater output. Forget using a MIG welder, they use a Constant Voltage power supply. You're probably more likely to find a good used welder for a decent price than a genuine plating supply in the size you want. |
Thanks for the input everyone! I am going to keep things small for now, then gradually move up to larger pieces for now. I just bought a power supply, although it is a Astron RS-35M, will this work for the anodizing of small items? it is rated at 15 volts and 35 amps. thanks!
Ben |
| using aluminum as a cathode | scocklin | Anodizing Questions | 19 | 03-31-2007 12:18 AM |
| Problems with tank temp | Slip666 | Anodizing Questions | 2 | 12-21-2006 12:46 AM |
| FYI. Curing different colors at the same time.. | boink | Powder Coating Questions | 5 | 09-11-2005 12:05 PM |
| Need opinions on my next tank. | jtsuttle | Anodizing Questions | 4 | 03-29-2004 12:32 PM |
| Tank Heating Questions. | meganine | Anodizing Questions | 1 | 08-03-2003 03:20 PM |
