My second attempt at anodizing-
estimated SA= 14sq inches, ASF@9 60xx or 7075 grade, not sure which. Brief etch in lye & water (@ 4-5 minutes) followed by a de-ox/de-smut Ano bath 80 minutes @low to mid 60s, next R.O dip, Dye (blue4A) about 3 minutes @90', another dip in R.O., Seal 20 minutes @160'+ (steaming hot!) Only one nut lost connection. There is some slight shadowing on one or two parts. |
As a newbie here can you tell me how temperature affects dye? I have noticed the blue 4a is really really dark (almost black) after 20 minutes. Those parts were barely in there 3 and they came out deeper than I expected.
SS,
If the makers said it that makes sense to me. Tuesday night I did another job but this time using violet and brought the temp up to about 110'. The parts took a while to absorb it. Once they were in about 10 minutes they began to look good. At 15 I pulled them and was 100% satisfied. Both times the material was mainly 7075. The nuts don't seem to need a de-smut so I'm thinking they are 6061. Maybe I need to do another job using blue and see what happens. Also, I need to get a candy thermometer and put it in my sealer tank to get a more accurate reading on temp. Thank you for your help. |
| my first attempt at vinyl masking | destroyer125 | Anodizing Questions | 1 | 05-12-2006 10:10 PM |
| First attempt of anodizing. | scamihorn | Anodizing Questions | 15 | 05-09-2006 03:34 PM |
| My first attempt: | Indy | Anodizing Questions | 12 | 02-03-2005 05:03 PM |
| First attempt at polishing, I ain't happy, help? | Forrestang | Metal Polishing Questions | 11 | 12-09-2003 12:01 AM |
| First Attempt - Paintball Gun Anodizing | d0n | Anodizing Questions | 2 | 11-02-2003 06:04 PM |
