Old 03-17-2007, 11:05 AM
pmac2002 is on a distinguished road
Default another rookie question for you seasoned vets....
Will a 3amp rectifier be better to anno than a battery charger?
I know from the calculator it says 6amps for x amount of minutes. Would the time be doubled if using 1/2 the amps?
thanks
Paul
Old 03-18-2007, 10:49 AM
sswee's Avatar
Moderator
Default Re: another rookie question for you seasoned vets....
thanks
Paul
A CC rectifier is the best to use.
That is 6 amps per square foot. You need to figure the surface area of the part to know how much current to use.
SS
Old 03-18-2007, 06:23 PM
ok not sure but right now all that is avvailable at caswell is the 3amp rect. according to the calculator this is going to just take a bit longer to anno?
also should I be using 1 to 1 for acid to water or 1 acid to 3 water?
thanks
Paul
Old 03-18-2007, 07:04 PM
sswee's Avatar
Moderator
The 3A rectifier from Caswell will work much better than a battery charger.
Use 1 part battery acid to 3 parts distilled water.
The anodize time required is directly dependent on current density. A 3 ASF (amps per square foot) is the lowest CD you want to use for anodizing. Any lower and the pore size will be too large to hold dye.
SS
Old 03-19-2007, 09:06 PM
rclint is an unknown quantity at this point
So if you have a sqaure piece of sheet aluminum (we wil not count sides because it's so thin) 4" tall by 5" wide
With the 3 amp power supply your talking about here is what it could come out as
4"x5"=20" you have two sides, so 20" x 2 = 40" total
You would run in CC mode, set the amps to 1.67 for a 6 amp current density run 84 minutes for a .7 mil coating
Hope this helps you figure out how to calculate the surface area compared to current density and what size power supply you need. On a normal part you measure out everything as close as you can for the square inches, then add them all up.
Clint
Old 03-20-2007, 12:08 PM
I have purchased a dc power supply that is 10amp 30volt! thanks for all of your help guys!
Paul
Rookie question aermakov@rogers.com Electroplating Questions 1 11-12-2002 03:24 PM
