I've been kicking around an idea in my head for a while and was wondering if anyone here has come up with a similar solution already. Caswell thermostats work great for the temperture range they were designed for, but for my cleaner, sealer and ano tank... they don't really apply (unless they could be modified?). So I'm thinking of using a line voltage thermostat with remote sensing probe from mcmaster or grainger. While I'm sure this would work... what I'd really like to have is a programmable line voltage thermostat with remote sensing probe. (So I don't need a seperate thermometer to see the temp at a glance.) Unfortunately I can't seem to find a product like this.
So my question is what have others done for there tanks that need higer or lower temps than the range that caswell's thermostats provide for? Thanks.
Justin Martin, VP Blackcote RR1 Box 116 Liverpool, PA 17045 www.blackcote.com blackcote@pa.net |
I use a baseboard heater thermostat for my ano tank (~68F), and hotwater tank thermostats for the higher temperatures.
They don't hold the temperature to within one or two degrees like I would prefer, but they are cheap. The hot tanks are no biggie, but the ano tank is heated to my target temp, then it automatically turns off... further monitoring is done manually. I monitor the temps with simple indoor/outdoor digital thermometers with the outside sensor placed directly on the side of the tanks. My Polar bear chiller has it's own built-in thermostat that switches on at 2deg over target, and off at 2deg under. It also has an auxilary 110v out that could control a heater. 4deg swing is quite a bit, but acceptable to me.
Yes, exactly, I have them attached to te exterior of the tank, then insulations over the outside of those.
In case anyone else is interested... I Finally found what I was looking for and they're even reasonably priced IMO. Not quite as cheap as caswell's thermostats, but seems like a nice product for temp control and monitoring in one unit.
mcmaster 1760K77 grainger 3ZP77 ebay has the grainger style which can be had for slightly less there. Only question I have yet is does the remote sensor have to be placed in a stainless tube or similar to protect it from the chemicals or will it be OK with direct contact? I'll have to shoot some emails and find out.
Good find!
SS housing won't work... it will need to be titanium, aluminum, glass or lead. I don't see why you couldn't just attach the probe to the exterior of the tank as long as it's insulated.
I tried looking for product info on the McMaster site, but didn't see any.
For the grainger part #.... it looks like it's not going to work without a bit of extra work. Should of figured as it was in the HVAC section. This is the manufacture's response.
| Better color chart for Caswell dyes? | luminous | Anodizing Questions | 19 | 04-11-2007 08:04 PM |
| powder dyes vs concentrate liquid dyes | whistule | Anodizing Questions | 3 | 08-21-2003 10:06 PM |
| Lead plates, anodising voltages and dyes | whistule | Anodizing Questions | 2 | 08-17-2003 09:58 PM |
| opaque anodizing dyes | july_favre | Anodizing Questions | 1 | 03-12-2003 08:26 PM |
| Anodizing using RIT dyes Question | Hcues1 | Anodizing Questions | 1 | 01-20-2003 12:30 PM |
