Hello Everyone!
I am looking for a supplier of Titanium tubing or a small "drop-in" titanium coil for a heat exchanger in my anodizing tank. I think a large coil of tubing laid flat in the bottom of the tank would be best, hopefully someone will point me in the right direction. Thanks in advance! Ben |
5ft. of titanium 1/4 tubbing runs $219.00 You would need at least 20ft running Etheline Glycol or anti freeze in a 50/50 mix with water pipe that into a automobile heater core and put that in a freezer running about -20 F you can get an electric fuel pump that will run it through fairly fast. So for less than a grand you can build a cooler out of titanium. Or do what most folks do and pump the same mix through plastic tubing only coil up say a hundred feet of the clear plastic tubing in about the same 1/4 inch size same effect Tygon PVC will run you about $60.00 for a hundred feet then you can use fittings to increase its size to fit the heater core. put it in a freezer at -20F it should cool your acid bath down quite quickly and a whole bunch cheaper. Now if you want to spend a couple of grand give it to me and I will build you the cheap one and guess WHAT. You won't know the difference. dray
I just got a quote from Vulcanium on a custom built Titanium coil for $169.00 that will fit my tank. I will probably use Aluminum tubing for a temporary coil and then do the Titanium one.
Thanks. Ben |
HTH
REDRIVER: You're still using the cool aid as a dye supplement aren't you? Avoid this... quadster: Kool-aid? Hummmmmmmm............ I havent even tryed Rit yet yet.....I could clean out a bunch of cabinet space.... mcaswell: Cool Aid? RIT? ...Will someone pour me a large JD to steady my nerves? |
| Using a Mag Drive pump for electrolyte circulation | NeoMoses | Anodizing Questions | 14 | 04-11-2007 02:10 AM |
