Just wondering who is using aluminum cathodes. From what I under stand you can use 1 sq foot cathode to every 3 sq foot anode. Is this the same for lead, does the aluminum produce better results?
One last question from what I have read it should be 6063T6 if you are using aluminum what are you using? |
Can't recall if mine are 6016 or 6061 but they are the ones from a chain hardware store. I think K&S sells them as well as other metal tubing, rods, etc.. Mine are 6x12 by 1/16 thick. My biggest job so far was about 45 sq inches. So far they have worked out well.
I am switching to aluminum next week- yay!
REDRIVER: You're still using the cool aid as a dye supplement aren't you? Avoid this... quadster: Kool-aid? Hummmmmmmm............ I havent even tryed Rit yet yet.....I could clean out a bunch of cabinet space.... mcaswell: Cool Aid? RIT? ...Will someone pour me a large JD to steady my nerves? |
I use 6061 sheets 12 x 12 x .060", on each side of my tank and it works great.
I do beleive that you should have more cathode area than anode area! I beleive it is up to 4 time more cathode area than anode area. Shane |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 07:37 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| using aluminum as a cathode | scocklin | Anodizing Questions | 19 | 03-31-2007 12:18 AM |
| Maintenance of Aluminum Cathodes | liv2fish2 | Anodizing Questions | 4 | 12-27-2006 01:25 PM |
| Clear Coating Aluminum Rims | sage | Powder Coating Questions | 2 | 08-03-2006 09:33 PM |
