Old 04-29-2007, 06:06 PM
hvacman250 is on a distinguished road
Default Questions on 720 rule and rectifier
1. I was planning on buying Caswell's 20 Amp Constant Current Rectifier , but they have been back-ordered for awhile. Any Caswell people know when this will be back in stock, or where I can buy something along the same lines?
2. I'm still confused by the 720 rule and how to apply it. ( I am using a 10 amp, 15 V DC power supply. There is an adjustment knob that I believe increases voltage; thtas it. If I turn it up, the voltage and amps go up)
Example: 190 total sq in / 144 = 1.32 sq ft
Target current density at 6
1.32 x 6 = 7.92 amps to the parts
I had my PS full blast, and it was drawing about 5 amps. Thats all I could get out of it. I ran at 2 hours (5xxx and 6xxx parts) and the dye took great (deep red).
But, I'm guessing I don't have a full 1 mil build. Is that so bad?
If I do 720 rule: 720/5 amps (pulling)= 144, 144 x 1.32 sq.' = 190 min in the tank
So I only did built a .66 mil because I did 2 hrs instead of 3?
Old 04-30-2007, 12:52 AM
Default Re: Questions on 720 rule and rectifier
Yes, you have it correct.
Your amps may be low because of a couple of factors:
Acid/water ratio will affect resistance.
Tank temperature will affect resistance.
15 volt PS may not be enough to run 6 amps per sq. ft.
Ano thickness will affect color. You'll want to ano to a full 1mil for black and other dark colors. .75mil is fine for medium colors, and .5mil for gold and clear.
GL
720 rule and time ???? jtagger19 Anodizing Questions 15 10-27-2008 09:58 AM
accuracy of the 720 rule kebo Anodizing Questions 7 06-16-2006 01:39 PM
Anodizing with a rectifier sgunn911 Anodizing Questions 1 06-24-2004 07:28 PM
