Old 02-11-2002, 12:04 PM
desert_roamer
Default Acid for anodizing
Is automotive battery acid the same mixture (1/3 acid, 2/3 water) from all sources? The plating manual recommends getting it from NAPA auto stores for use in anodizing, but I have some from a different source. Does it matter as long as its automotive battery acid?
Old 02-13-2002, 11:54 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: Acid for anodizing
It should all be virtually the same.
Semi-related note: Some people try to use sulfuric acid instead of battery acid....it's not the same concentration and doesn't work out of the bottle.
Have A Web Site?
Old 03-13-2002, 01:42 PM
ketanjajal
Default Re: Re: Acid for anodizing
Can you tell me the exact concentration by volume/weight or Molarity. I need this since I have limited supplier from whom i can buy.
thanks
Ketan
Old 03-13-2002, 04:22 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: Plug n plate kit for bathroom faucets ?
1.26 baum
Have A Web Site?
Old 07-25-2002, 04:37 PM
dburg507
Send a message via AIM to dburg507 Send a message via Yahoo to dburg507
Semi-related note: Some people try to use sulfuric acid instead of battery acid....it\'s not the same concentration and doesn\'t work out of the bottle.
Hello,
Hope you don\'t mind if I add on to this thread, but what you said caught my eye about sulfuric acid not working out of the box. Can you give a little more detail on that. Reason being we currently use battery acid but my partner seems to think we should switch to sulfuric acid. I did some research and I\'m not sure if I want to use that stuff. If can tell me what the pro\'s and con\'s are that would be great.
Thanks in advance
Old 07-25-2002, 09:10 PM
mcaswell's Avatar
Caswell Inc Founder
Battery acid is mostly, but not 100% sulfuric acid. Sulfuric acid is 100% sulfuric acid.
We recommend battery acid for our kits and processes. Some people may find sulfuric acid works best in other products. It\'s really up to you to experiment.
Have A Web Site?
Acid SniperSlayer Anodizing Questions 8 07-25-2005 09:59 PM
Acid copper Gabourie Electroplating Questions 3 09-25-2004 08:42 PM
"Sandwiching" Acid Copper AresP Electroplating Questions 1 08-27-2004 08:19 PM
Acid concentration versus current density M_D Anodizing Questions 7 02-04-2004 09:01 PM
Acid Bath Content? Chevalier Anodizing Questions 3 01-12-2004 10:46 PM
