Old 03-12-2003, 07:54 PM
erogers
Default Basic anodize questions
The Caswell Manual says 2-3 minutes per .0001 depth of anodize, on the kits/aluminum.htm page it says 7 minutes per .0001 depth. Which is correct?
Also, the manual states that for hardcoat you use 4/2 mix of distilled water and battery acid, and dye anodize, is a 2/2 mix. Is this correct, or is it backwards? I believe it was at the American Anodize Assoc. that i read that it was the opposite?
One last question. Can tri-sodium-phosphate (TSP) be used as a cleaner, or as a mild etchant?
LCD anodize of a large piece? scocklin Anodizing Questions 2 12-29-2004 12:21 AM
Combined powder coat & anodize seanc Powder Coating Questions 3 09-03-2004 12:31 PM
Questions from a wanna be... cusackmusic Anodizing Questions 1 01-09-2004 03:45 PM
A question for the anodize boys from the powder guy non-stick Anodizing Questions 3 11-26-2003 04:22 PM
Fumes and basic newbie questions PeterBusch Anodizing Questions 7 10-05-2003 09:30 PM
