Kind of funny when I'm posting advice in a question thread that I originally posted
.Anyway, I bought that $100 unit you posted and it's terrible. It does get the job done for not much money, but I'm constantly having to pick it up and shake it to get the beads unclogged because of the cheap suction fed system (I'm thinking about jerry rigging a gravity fed system). EDIT - also, make sure you get a compressor with close to the same CFM as your blasting cabinet otherwise you'll have to wait all the time for your compressor to regain pressure. Last edited by mkriegs; 04-07-2008 at 07:19 PM. |
My compressor is a monster, so I have no input what the minimal size might be, but the required CFM should be listed or recommended with the blast cabinet.
The compressor absolutely needs to be 220vac, and the bigger the tank the better. Then you'll need a good water seperator/filter/regulator. I usually blast at around 60psi, and just a quick back and forth dusting is all your need. If you over blast, it'll come out blotchy. As far as shaking the cabinet to get the blast media down... never had to do that. I keep the hopper pretty full.
So you're saying that you just fill it up as much as you want and you don't get problems? |
I fill mine all the way to the screen... problem solved!
I got my bead blast cabinet at Harbor Freight for under $100. Its a bench top model, but I used 2x4s I had in the shop to build a stand with wheels. It was a nice unit; came with everything I needed including 4-5 different sized nozzles and extra plastic sheets to protect the glass viewing piece.
As for a compressor, I bought a 21 gallon from HF too. It was on sale for $150ish. I didnt expect it to last long, buts its been running a year with no problems. I use it for agitation and blasting. Sears sells a 175 psi 30 gallon for around $250-275 that I plan on buying next. As for blasting, I buy my 80 grit glass beads at HF and blast at around 65 psi. Oh, and mine says 5 lbs max too. I have about 25 in it Last edited by hvacman250; 04-12-2008 at 11:05 PM. |
| A few questions from those that know. | JTW37 | Powder Coating Questions | 4 | 04-05-2007 10:59 PM |
| Zinc Plug N Plate Dark Streaks/Coverage Capacity Questions | ms042180 | Electroplating Questions | 3 | 12-21-2006 11:48 AM |
| Wanting to do golf clubs - some basic questions | tcpip95 | Electroplating Questions | 1 | 11-14-2006 12:35 PM |
| Some newbie questions... | kiwijetpilot | Anodizing Questions | 16 | 03-12-2005 08:18 PM |
| A few newbe questions | thestormfamily | Electroplating Questions | 4 | 06-30-2004 08:54 AM |
