We just got a RFQ for this part for anodizing 40 of them clear, but need to mask it in the areas I've colored red. I've estimated the SA at to draw about 8 amps a piece at 6ASF and I think we can only do 2 in a batch, maybe 3 if I play with the current density and time. I've not had much experience with masking yet so I was curious what the general consensus was for masking this? Do you us the Caswell Mask It ruber cement type stuff or some kind of tape or a combination of both or some other ingenious ideas? Part is about 5x5x2.25.
Justin Martin, VP Blackcote RR1 Box 116 Liverpool, PA 17045 www.blackcote.com blackcote@pa.net |
Anyone want to guesstimate how long something like this takes to mask with mask it? I tried using the mask it on a test piece once and it took a forever to do a 1.5" diameter circle, and it was difficult to keep it from getting in a groove next to the mask. Was pretty difficult to remove as well, but I think I read somewhere that lacquer thinner helps in that department. Anyone have tips on best practices while using the stuff?
Nope, print says only surfaces shown, would be worth asking though. Seems the quote requestor is only a secratary and doesn't know anything about the function of the part, so were stuck with following the print to the T. Besides there's thu hole slots in the top that would let the electrolyte in. Nice idea though.
Perhaps make a stencil of some sort so you can just spray or brush the mask on easier without getting it in the "forbidden zones". - |
hmmm stencil.... I see possibilities there. take a plastic folder or similar and cut it up and mask away not sure how I'd use a stencil to keep it from running down the side though. and spraying the mask... I like the concept but seems like it'd be hard to keep overspray from getting to unwanted areas even with a stencil. This seems like a job for tape of sorts (not sure how) but is there any that with stand 180 deg cleaner and hold up to the electrolyte.
Hmmmm... thinking about this a bit more I think I'd use tape around the ousides for spray or brush application, maybe tape inside wall as well too keep from spraying or running down the inside of the part. not sure what to do with that groove though then. Not sure yet how I'd approach the depressed area though. I just think it will be an uneven line in the corners if masking with mask it. Ideally we'd have a few masking fixtures built, but I don't think 40 pcs. qualifies for that.
I could cut masks for you using my Roland cutter and 3M vinyl. All I need is an accurate Jpeg, and dimensions. PM me if you want to try it.
•Inferno Custom Paintball•
PM sent. Thank you for the heads up.
| Masking products? | SX Paintball | Anodizing Questions | 4 | 02-14-2007 12:59 AM |
| Big Oven Up For Bid | powdersparky | Powder Coating Questions | 1 | 01-26-2007 05:17 PM |
| Looking for a MASKING product for blasting ops | Halliwell1 | Other Metal Finishing Questions | 3 | 04-21-2004 07:23 PM |
| Masking products for EN plating? | edclark | Electroplating Questions | 0 | 12-23-2003 03:41 PM |
| Looking for masking tape recomendations. | chcarver | Metal Polishing Questions | 0 | 03-06-2003 02:51 PM |
