Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 08-10-2007, 04:13 PM
PBInferno is on a distinguished road
Send a message via AIM to PBInferno
Default Vinyl Masking Problem
I had a local sign company cut me some vinyl logos for masking parts, but every time I try to stick the vinyl to the part after dying it, the backing leaves a residue on the part. This residue keeps the underlying dye from bleaching out, which leaves a large area of the wrong color around the logo.
Any advice on how to keep this from happening?
Thanks
•Inferno Custom Paintball•
Old 08-10-2007, 04:16 PM
destroyer125's Avatar
Default Re: Vinyl Masking Problem
you cant use transfertape with the stickers.
Old 08-11-2007, 07:21 AM
LOON is on a distinguished road
You should try the clear backing...it's less sticky...
additionally rub over the backings glued side to minimize the stickiness....after that it could be "hard" work to get the vinyl off the silicone-paper.....but who cares, if it works
That works perfectly for me....but I'm doing single-pieces, mostly....
Old 08-12-2007, 12:48 AM
If you could cut deep enough to cut the backing on the sticker that the vinyl comes on.... you could stick transfer tape on the sticker, and spray the sticker/transfer tape with some kind of spray adhesive....then pull the wax paper off to use it....not sure how well it would work but it would definately be worth a try. Mainly just mask the sticky stuff on the transfer tape
*Cough*Acidrain*Cough*
Closed Thread
Problem with dyes @ masking LOON Anodizing Questions 3 05-12-2007 08:15 PM
Vinyl Masking Thefool Anodizing Questions 3 09-24-2006 09:04 PM
Vinyl working destroyer125 Anodizing Questions 7 07-10-2006 01:38 PM
Vinyl Printers/tatoos yoyoboy Anodizing Questions 4 06-29-2006 03:46 AM
my first attempt at vinyl masking destroyer125 Anodizing Questions 1 05-12-2006 11:10 PM
