Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 10-27-2007, 11:55 AM
fourkbmx is on a distinguished road
Default agitation
im trying to step things up and im building a new large system, but my main problem is the agitation, the thing is that in my small tank i used a fish tank bubble blower to kip the hidrogen out of the anode, but for my new tank, im going to use a water pump, for keeping the acid running, but i dont know if i should stay with the bubble blower too?(my new tank is 20gal)
Old 10-27-2007, 03:08 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: agitation
It takes a pretty big acid pump to make a difference. If you have a shop compressor, that will work really good for just air agitation if you add in-line filtration. Use 1/2in PVC to make a grid and drill 1/16in holes every 3in or so. You'll have to weigh down the grid or it will float when you charge it with air.
I do things.
Closed Thread
Voltage goes up with AGITATION? Ready2Dye Anodizing Questions 4 03-28-2007 11:50 PM
Air agitation of dyes? SX Paintball Anodizing Questions 1 03-28-2007 10:48 PM
Agitation pump, what are you using? MrPontiac Electroplating Questions 2 01-20-2007 08:10 PM
Agitation hurricaneracing Anodizing Questions 3 11-15-2006 11:40 PM
Agitation ??? hurricaneracing Anodizing Questions 1 08-30-2006 04:53 AM
