Old 11-03-2007, 09:40 PM
fourkbmx is on a distinguished road
Lightbulb power source
i just bought a new power source for my new tank, is 5A 30V with both regulated, but im having trouble setting the volts, every time im trying to set volts up for quicker process my power source shuts down, this is a pic of the new source.
Old 11-04-2007, 01:27 AM
sswee's Avatar
Moderator
Default Re: power source
I'm not familiar with that particular PS.
Have you tried dialing the amps down to 0A, dial up the volts to approx. 25V and then slowly dial up the amps to the calculated set current for the run?
You should have the voltage turned up all the time and adjust the amperage needed for the run. The voltage should adjust itself to the level needed for the set current unless the PS is not CC/CV capable.
SS
power source fourkbmx Anodizing Questions 4 10-26-2007 02:34 AM
power source 93FATBOY Copy Chrome Kit Customers Only 4 10-04-2006 09:52 PM
Plating Power Source. mtumbleson Electroplating Questions 2 09-07-2005 11:07 AM
12v power source using Nichrome?? phunkmastakrez Electroplating Questions 1 08-18-2005 06:18 PM
Power source question spectraflamed Electroplating Questions 2 04-07-2002 07:56 PM
