hi, i finally finished my new tank, and solve the power source problems, and now im having great anodizing results, but im off dyes, so i started using textile dyes, some of the dyes worked just fine, but some other just don't, i've never used caswell's dyes, but im interested in purchase some, im just curious about the quality and the results you can get, also i would like to know if i need to buy a sealent for this dyes, and what is the difference between caswell's sealant and just water used as sealant. thanks.
Yeah, the textile dyes are ****, and not much cheaper that Caswell's.
All of the Caswell dyes are made for ano, and will give you great results. There is a stickied thread at the top that gives PH levels for each. I've never had to adjust mine, but others have said to keep an eye on the PH for best results. As for sealant, I use the high-temp nickel sealer. I've never "steam sealed", but others have and will work fine.
| Refreshing dyes | LOON | Anodizing Questions | 1 | 10-24-2007 08:59 PM |
| Dilute dyes? | kco1196 | Anodizing Questions | 4 | 03-14-2007 12:00 AM |
| UV Dyes | kickn | Anodizing Questions | 0 | 09-07-2004 04:35 AM |
| ph range of dyes | ase618 | Anodizing Questions | 0 | 01-20-2004 06:44 PM |
| powder dyes vs concentrate liquid dyes | whistule | Anodizing Questions | 3 | 08-21-2003 10:06 PM |
