Old 11-12-2007, 07:43 PM
fourkbmx is on a distinguished road
Lightbulb white ano
since there is not white dye, does anyone know the right procedure to turn aluminium white, please explain the process, and if you can please use a synonim for "bead blasting"
Old 11-13-2007, 05:19 AM
FigureLLC's Avatar
FigureLLC is on a distinguished road
Default Re: white ano
i use powder coat. bead blasting = sand blasting with glass beads or pellets. or could be other blasting media, but i think beads are usually glass? if you're anodizing, i don't think blasting is the way to go, bc it'll leave a rough finish that will make the anodizing look bad, but then i don't anodize.
Len
Figure Engineering, LLC
Old 11-13-2007, 11:51 PM
PBInferno is on a distinguished road
Send a message via AIM to PBInferno
Correct, beadblasting is like sandblasting, only with fine glass media as opposed to sand. When I want to do a "white" finish, I just beadblast the part prior to anodizing, and then go directly to the sealer (no dye). Here's a pic of a paintball marker done using this process:
•Inferno Custom Paintball•
Old 11-13-2007, 11:55 PM
Bead blasting is glass media blasting with very fine clean glass beads. It leaves a "dust" finish. The beads I use are smaller than granular sugar.
It takes a very light dusting... too much pressure or if nozzle too close, the part will turn out blotchy.
When anodizing a part that is going to be left clear, the part must be absolutly perfect before going in the tank.
Also, I usually ano to only .5mil so that the ano doesn't turn yellow, then seal normally.
Here is a dust clear compared to white powder coating:
Old 11-14-2007, 12:25 AM
thanks a lot for the info, do you think i'll get the same result if i prepare the part using caustic soda bath before going in the tank, instead of bead blasting?
Old 11-14-2007, 12:58 AM
I have not had good luck using etch as a method of finishing a surface. Try some experiments and see what you think.
Old 11-14-2007, 09:10 AM
FigureLLC's Avatar
that paintball gun it hot! that's a sweet technique.
i have experimented with sodium hydroxide and it sucked.
Len
  #8 (permalink)
Old 11-15-2007, 09:04 PM
i did some experiments, with no good results, do you know a cheaper method for giving a bead blasted finish? or a way to make a home made blaster?
  #9 (permalink)
Old 11-15-2007, 10:27 PM
You can pick up a fairly cheap blast cabinet from Harbor freight for less than $100. Either add a light, or get one with a light.
A 50lb bag of glass beads will run $35-$50. There really is no substitute.
And then you'll need an air compressor too.
  #10 (permalink)
Old 11-16-2007, 07:56 AM
FigureLLC's Avatar
why no substitute for glass beads in this application? so glass beads are good for anodizing, but bad for powder?
Len
white dye?? anno boostboy97 Anodizing Questions 2 02-21-2007 03:17 PM
What is 'white' metal? dfarning Plating Pot Metal 5 12-05-2006 07:21 AM
Pearlescent white? supermatty Powder Coating Questions 0 10-15-2006 03:42 AM
white haze UFpball7 Electroplating Questions 6 04-13-2006 02:32 PM
white dye deepanod Anodizing Questions 4 03-28-2005 04:48 PM
Powered by vBulletin® Version 3.7.0
