Old 11-19-2007, 07:34 PM
roznerd is on a distinguished road
Default Deep Red came out Fuschia
Hi guys - I have been having good luck with my LCD setup so far. I have made some nice Black parts and had good results with Fast Blue.
When I dyed my parts with the Deep Red, I ended up with a voilet/fuschia color. I dyed at 140F for 15min and sealed with the Caswell Sealer as directed. In a 2nd attempt I dyed for 2min and still got a fuschia/pink color.
What could be causing this?
Did I make the dye wrong or something? (too much dye, not enough water...)
The specs are
3:1 water/acid 1 qrt capacity
lead sheet cathode
anodizing time worked out to be 100 min
acid temp = 70F
Everything was done with distilled water
Parts were polished 6061-T6
In the container the dye even looks a like sort of bright fuschia colored.
I really want a Red color like you see on racecar hose fittings.
Let me know what you think. Thanks
Old 11-19-2007, 10:29 PM
hvacman250 is on a distinguished road
Default Re: Deep Red came out Fuschia
I use deep red all the time. The above pic is deep red, anodized to 1 mil, about 5 minutes in dye, so it can get darker.
Old 11-19-2007, 11:04 PM
Same here... my deep red comes out very red.
You didn't say what thickness you went for. Be sure to ano to a full 1 mil.
Does your mixed dye look dark red (it should). There is a remote possiblity you were given pink instead of red.
The other possibility is that your PH is off, or your mix is too week. Did you get every trace of dye out of the bottle when mixing?
Usually when the dye barely works, it's an indication of a lost connection. Any possiblity of that? If you used aluminum wire, check to see if the wires dyed, but the parts didn't.
Old 11-20-2007, 12:42 PM
HVAC - That's the exact red I was hoping for. The bottle says Deep Red. I wonder if this was Caswell's mistake?
Acidrain - I'm sure I had a good connection because the dye took, but I'm not sure what my layer thickness was. It might be a little thin. I used the (720/current)*SA to get the acid time. I'm using the ghetto let'r rip PS method, but I don't think that should effect this color stuff since I'm making nice blacks, and blues from the same batch.
Here's a pic of my parts.
When I made the dye, I only wanted one pint, so I measured out the full contents of the bottle in a graduated cylinder and then divided it by 16. I added that amount (~6.5ml) to my pint of dist. H2o. This trickery might be the source of my problems. Maybe I should mix up the full 2 gallons just to make sure it's right.
Unless, I can play with the PH. I don't have any way of measuring the PH though.
Old 11-20-2007, 04:16 PM
jwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of light
Please contact us regarding this matter. 315-946-1213.
Thank you.
Old 11-24-2007, 11:46 AM
radmaximus's Avatar
radmaximus is an unknown quantity at this point
Hey roznerd did you just get the dye from them, I had the same problem. They had the wrong dye in the deep red bottle, I received violet dye in a deep red marked bottle, thats probably what happened! They sent me a new bottle of red and it is now correct color.
PS. Thanks to Caswell for quickly correcting the problem!
Rad
Old 11-26-2007, 07:37 AM
Z Z is offline
Z is on a distinguished road
you probably want to get a way to test the ph in your tanks. ph can drastically change the color.
  #8 (permalink)
Old 11-26-2007, 06:53 PM
Rad - They did the same for me. I guess there was a labeling mix up. A new Deep Red is on the way.
Thanks Caswell for the great customer service!
Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled frubino Anodizing Questions 1 07-27-2004 01:56 PM
Jumping in the deep end. Mad_Professor Electroplating Questions 3 12-23-2003 10:45 AM
removing deep scratches from large areas lenise Metal Polishing Questions 1 03-11-2003 12:56 AM
