im having trouble with the sealant i just bought, the colors after the ano are great, but after sealed the piece has white spots, and looses a bit of the color. yesterday y dyed two pieces that have the same dimensions and i did the same process on both, but i left one unsealed, and today the one unsealed has the same color than yesterday but the one sealed look like i said before, any ideas what is wrong??(im using the caswell's sealant the one that uses 1oz per gal)
Are you boiling (or near boiling) the part for 20 minutes?
Removing from the hot sealer, and emediately going to a dunk rinse tank, then spraying with WD-40 and wipe clean?
sealer tank needs to be stainless steel or plastic(polypropylene), and made up of D.I. water. If you use S.S. make sure you insulate the load bar if its metal so you don't have any stray currents that will cause pitting or white spots if there are chlorides present.
white spots are mainly caused by impurities in the water. |
I've had problems with metal tanks ruining the sealer... the sealer turned cloudy and left deposits. Is your sealer nice and clear/green? If it's milky the sealer is ruined.
| Polished Brass Sealant | hoytheld | Metal Polishing Questions | 2 | 02-26-2007 02:51 PM |
| Anodizing Sealant LT | jqmah | Anodizing Questions | 0 | 06-17-2005 10:54 AM |
| lt sealant | dropride | Anodizing Questions | 3 | 07-16-2003 04:35 PM |
| LT sealant questions | desert_roamer | Anodizing Questions | 1 | 07-09-2003 06:01 PM |
| Low temp. anodize sealant | tool_man | Anodizing Questions | 2 | 03-12-2003 08:07 PM |
