Ok so I stripped and beadblasted the parts and it got rid of that stuff, whatever it was, but it left some pretty deep indentations in the parts. I was able to polish most of them out, though.
Also, I tried running a spare piece of 6061 today and I noticed something interesting. A red buildup develops on my cathodes after a couple days of not anodizing, and whenever I used to anodize using constant voltage, it would always come off the cathodes almost immediately after the power supply was turned on. But today when I tried to run constant current, the buildup stayed on the cathodes the whole time, even though the power supply was putting out 30V when set to .4 amps. What could cause this? And any clue what's going on with my black dye?
•Inferno Custom Paintball•
I can let the part dye for 30+ minutes at 140* and when it comes out it'll be a perfect black. But then the air hits it and it immediately fades to bronze-ish. One part I kept spraying with distilled water after it came out of the dye tank, and all the areas I sprayed kept their color perfectly. I don't get it.
i solve the problem!! i had a little idea of what the problem was on the pic i posted, and yesterday i tried my theory, i found out that the piece was covered by an unknown material this happened because i had some kind of contamination in my tank so yesterday during a run i dip a little copper piece, and kept it there during all the run, i cut the agitation and kept an eye during the whole run and i observed that the copper started to disapear and at the end of the run the aluminium piece was full of a copper surface, and there were no traces of the copper piece in the tank, so for conclusion i think this was the problem you experimented, is this was the case, we need to be more carefull with the contamination.
Well I recently had an incident with the heating unit for my tank malfunctioning and contaminating the acid bath, so it looks like I'll have to replace it anyways. Once I get enough money to get everything going again, I'll let you know if that solved my problem.
| so i have a problem | LNZcustoms | Powder Coating Questions | 6 | 01-01-2007 09:43 AM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 05:21 PM |
| Problem with new set up. | GramSlam | Anodizing Questions | 12 | 10-05-2004 07:40 PM |
| Problem with gun... | daveg | Powder Coating Questions | 2 | 03-09-2004 10:27 PM |
