This book contains just about everything you need to know about anodizing, also has hard coat anodizing and chromating.
https://www.efinishing.com/html/probert.html |
I haven't come across any negative sides, the colors come out deep. I suppose if I heated the dye I could probably cut my dye immersion time down some but that would be only like 5-10 mins.
he uses 12 amps per square foot at 15v how is that posible, i guess the 720 rule doesn't apply here, i do my runs at 12amps, 30 volts no matter what alloy im using im doing things wrong i guess does any one has the voltage vs alloy info?
The 720 rule applys only to 1:3 battery acid/water.
