Ok,I am back again because I can't figure this problem out at all.It is really aggravating me.I bought sp degreaser mixed to right ratio.I have done everything under this world to try and fix this to my knowledge.I have a pic this time to help explain my problem since pictures are worth 1000 words.In case you forgot the problem is the dull spots.
![]() Please please please help me. |
Are you giving it just a quick dunk in the SP degreaser? The degreaser will leave dull patches if left in for more than just a few seconds.
Try degreasing with lacquer thinner, then dipping in the warm SP degreaser for just a few seconds to pass WB.
wow thx a ton acid fix the problem right up.However a new problem has arose lol.Can some one tell me the reason for this?
http://i42.photobucket.com/albums/e3...3/106_1148.jpg http://i42.photobucket.com/albums/e3...3/106_1150.jpg http://i42.photobucket.com/albums/e3...3/106_1152.jpg any help will be appreciated |
Something with your dye process I'll guess. Were the parts touching each other or the sides of the tank either during dye or sealing? They have to hang so they don't touch.
How about after dye? Were the parts allowed to dry or lay on a towel or something? After dyeing, let them hang in a rinse tank, or rinse and go directly to sealer.
Alright,I know what caused them.Can someone explain what desolation is?Or what ever it is when amps are to high,temp to high,run time to long.What is signs of this?I ran some more black parts with the same exact prepping process as the lime parts and ended up with smudges again.Could it be the black?Why is my black taking like 30-45 mins to turn a full black at a min of 140 degrees?
I doubt the smudges are from desoltion. You are probably experiencing multiple problems. If the black is taking a long time to dye, then the coating is too thin, or the dye is not hot. Could be PH level, but usually that makes the color off too.
Are you touching the parts with bare hands? Are you rinsing with RO or distilled water? Are you doing the entire process all at once, or maybe letting the parts sit? Are you rinsing really well? Between all the steps? Both dunk rinse, and spray rinse?
| Can you figure out what I did wrong? | cruizer | Powder Coating Questions | 11 | 07-17-2006 03:34 PM |
| Just trying to figure out everything I need to start PC | emopunk96 | Powder Coating Questions | 1 | 04-12-2006 08:32 AM |
| cant figure out the chrome | Carcher7878 | Powder Coating Questions | 2 | 05-21-2004 01:05 PM |
