Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
  #11 (permalink)
Old 02-13-2008, 02:58 PM
M_D M_D is offline
M_D
Default Re: PH for all tanks
We use SP cleaner from Caswell, heated to about 160-170 degrees F. It works well for our parts that are machined with water soluable oil and then tumbled with with plastic media and Raytech compound C detergent, which leaves the parts pretty clean. For parts that we machine with a petroleum based oil, we run two cleaning tanks (with the same cleaner). We use older cleaner solution in a "pre-cleaner" tank to remove the bulk of the petroleum based oil so the main "final" cleaner tank stays good longer.
  #12 (permalink)
Old 02-13-2008, 05:20 PM
destroyer125's Avatar
removing petro based oils is mainly what I need to remove, any idea on that cleaner?
  #13 (permalink)
Old 02-13-2008, 09:47 PM
M_D M_D is offline
M_D
Sorry, I wasn't very clear. The heated SP cleaner seems to remove the petroleum oil ok. Every once in a while we change out the main cleaner/degreasing tank, and use the older used cleaner for the pre-cleaner tank. If something were to have a lot of oil on it, we have used solvents like paint thinner or Stoddard solvent to remove the bulk of the oil to make the heated cleaner solutions last longer.
Closed Thread
Fuel Tanks Swampy Metal Polishing Questions 3 03-06-2008 03:18 PM
heating tanks... nil8u Electroplating Questions 3 03-05-2007 01:50 AM
How Many tanks ? micronind Electroplating Questions 0 03-03-2007 12:16 PM
Looking for tanks hurricaneracing Anodizing Questions 2 11-14-2006 10:28 PM
air tanks for air ride for car lowgmc94 Powder Coating Questions 1 02-11-2005 07:33 PM
