Can an anodizer do anything to cause marks like these? The customer claims these were perfect when they left his hands. So I'm looking to find out what we done wrong if anything.
Justin Martin, VP Blackcote RR1 Box 116 Liverpool, PA 17045 www.blackcote.com blackcote@pa.net |
Here's two more.
no stripper used, these are new parts.
pitting from what though? can too long in cleaner do it? and if so, why does it happen on only 2 out of 17 parts all processed at the same time,
pitting occurs do to impurities in the the tanks. Chlorides in the sulfuric acid tank causes pitting also stray currents. If you use a metal for your sealer tank and use metal for your load bar it can cause pitting when chlorides are present.
What's considered a chloride? and how does it get to my tanks? Can a black oxide line contribute to this? We run a large hot black oxide line in the same building, but not at the same time and we keep lids on all the tanks containing anodizing chemicals when not in use. Not air tight but fully covered. Edit: I guess this is where it could be as we use sodium chloride for blackening. Is there anyway I could check for chloride levels to know when to change it out... as building another building is not an option. Edit: My bad, we actually use sodium hydroxide.
Although we're using a plastic tank for all tanks, can you explain your thoughts or facts on chlorides in the sealer causing pitting? Can I rule out leaving it in the cleaner too long? We use the sp degreaser.
Justin Martin, VP Blackcote RR1 Box 116 Liverpool, PA 17045 www.blackcote.com blackcote@pa.net Last edited by blackcote; 02-13-2008 at 04:34 PM. |
chrorides are present in tap water, you should check out you are using destilled water, i've some similar problems before becasuse i didnt used destilled water. use only tap water after the sealing
in tap private well water?
| What am I doing wrong? | jpmassey | Powder Coating Questions | 12 | 10-19-2007 04:50 PM |
| Ok,what am I doing wrong | mach1man | Metal Polishing Questions | 1 | 08-18-2004 07:31 PM |
| ok, what am i doing wrong?please help a man out? | dgc187 | Metal Polishing Questions | 12 | 06-30-2004 05:41 PM |
| What's wrong here...... | dsacco1013 | Powder Coating Questions | 2 | 01-05-2004 10:15 PM |
| What am I doing wrong here | PC101 | Powder Coating Questions | 3 | 06-29-2003 10:14 PM |
