Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 02-27-2008, 04:59 AM
rogalxxx is on a distinguished road
Default What power supply?
Hi!
First of all I'd like to say hi, cos im new here.
I have a question regarding the battery charger.
I know that i need one with as much manual control as i can get. The problem is that all the chargers i found have this short circuit safety feature. I'd like to know if putting electrodes into sulphuric acid solution would short circuit the charger and shut it down? I'm not an expert but annodising is "work" and tha same thing is charging a battery, so the charger should not "feel" too much difference, right?
I'm thinking about this little fella:
http://allegro.pl/item318789098_pros...du_polski.html
i know it's in polish but basic specs are quite obvious it has a regulated current 0-15A.
or should i go with a specialized DC power supply?
http://allegro.pl/item313346302__zas...at_od_ss_.html
I know that 5A could be insufficient to anno a paintball marker body...yes, I'm going to start a garage-size anno shop mostly for paintball guns.
thank you for any comments
Old 02-27-2008, 04:18 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: What power supply?
You really need a CC/CV power source. The first one won't cut it, but the second one is the right type, but too small.
For PB guns, you're going to need a 10A / 15V minimum... I use a 20A / 30V Mastec, and have had good results. They are available on Ebay for ~$250 USD.
I do things.
Old 02-27-2008, 05:36 PM
thank you acidrain
damn, getting one of these shipped to Poland would be a pain...
On polish ebay I found a 0-30V 0-10A for 150$.
http://allegro.pl/item316166265_zasi...0v_0_10a_.html
I think it's a Mastech.
Old 02-28-2008, 02:34 AM
acidrain's Avatar
Yeah, that looks like a good one. Does it come with a warranty?
I do things.
Old 02-28-2008, 03:41 AM
no warranty on this one I'll keep looking. I think the ideal one would be a russian "made to last-tank steel made-atomic blast proof-late 60's" power supply. They're bulky but they do work great.
anyway thank you for your help
Old 02-28-2008, 09:39 AM
so what about battery chargers? would putting electrodes into acid bath cause it to shut down due to the short-cutting safety feature?
Old 02-28-2008, 03:42 PM
acidrain's Avatar
Probably would be no problem except they are not CC.
Only problem is if they are "automatic chargers". That would cause a shutdown of the unit part way through ano.
I do things.
  #8 (permalink)
Old 03-11-2008, 02:59 PM
  #9 (permalink)
Old 03-12-2008, 04:54 AM
how difficult it is to achieve constant results when dividing a paintball gun into let's say two batches of parts? Will I be able to match colors more or less, when carefully managing temps and current values?
All I can afford right now is a 13.8V 5A lab power supply (that's 40$ -the one i posted earlier ).
Of course I'll practice with lots of aluminum leftovers, diferent shapes and sizes, before I anno my 05 cyborg
Closed Thread
Power Supply Help Susanto Anodizing Questions 1 09-19-2006 02:54 PM
Power supply hurricaneracing Anodizing Questions 3 09-03-2006 09:42 PM
power supply Techno Electroplating Questions 0 09-20-2005 09:58 PM
power supply jamerson Anodizing Questions 8 05-07-2005 04:43 PM
New power supply? Tim Wiltse Anodizing Questions 7 10-23-2003 06:26 PM
