Hey guys,
I just tryed to anodize my first part and it went fine I just left it in there for 15 min not the recomened 90min. So after figuring out if should have been 90 min I tryed it out the next day and none of my parts bubble... anode or cathode... I'm trying to figure out what I'm doing wrong. It's set at 12 volts 2 amps. Any help will be awesome. Thanks, Nick |
You probably have a very thin anodize layer on there. Anodize is an insulator, so you're not able to get any power to your part now.
Strip the thin anodize off, and try again.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
Your parts aren't necessarily supposed to bubble... it's not what you look for.
Run the parts with good connections for the entire time, and then dye them. If they don't dye, then you have a problem.
Hello,
Thank you for the help! It worked after I stripped them for a long period of time. I dyed them and the fast blue came out like a UNC blue or transparent blue. Is there any way to make the dye darker? And is the part done anodizing after the bubbles stop? Thanks, nick |
It sounds like you need to go back and study up on the entire anodizing process...
Measure the total surface area of your parts. Calculate your current and time needs per the 720 rule. Anodize at the correct current for the time calculated. I suggest using 6 amps per sq. ft. current density, and anodizing to a full 1mil thickness for good color depth.
| GOLD PLATING OF LARGE MOTORCYCLE PARTS NEEDED i.e. RIMS, SWINGARM, OTHER PARTS!! | REVS | Services Offered/Wanted | 1 | 12-28-2007 12:36 PM |
| Looking for someone to re-anodize some parts for me | z71 | Services Offered/Wanted | 0 | 12-27-2006 06:24 PM |
| anodize fishing reel parts | tocold4u2 | Anodizing Questions | 1 | 10-02-2005 07:43 PM |
| How much to anodize? | fade2black | Anodizing Questions | 3 | 02-02-2004 09:20 PM |
| OEM looking anodize | SS65 | Anodizing Questions | 4 | 04-24-2003 10:31 PM |
