Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 05-01-2008, 08:22 AM
jsu jsu is offline
jsu is on a distinguished road
Default Part wont retain dye
Hey everyone, i started anodizing a few months ago as a supplement to my hobbies. basically recently i have been doing parts and when iam done dying they look very nice and actually seem to have a satin texture when dry. basically after boiling the part (ive tried long periods aswell) it seems to retain the color until you go at it with a cloth. then half ~ of it comes off. any ideas on how to stop this? thanks!
Old 05-01-2008, 09:18 AM
Z Z is offline
Z is on a distinguished road
Default Re: Part wont retain dye
Have you tried dumping your sealer tank and starting a new one? Sounds kinda like the dye could be leaching into the sealer bath.
Old 05-01-2008, 10:16 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Before you dump the sealer, are the wires anodizing? Usually when the dye won't take, it's because you lost connection sometime during the run. In that case, the aluminum hanging wires will ano, but not the parts.
I do things.
Old 05-02-2008, 06:30 AM
jsu jsu is offline
the aluminum is taking some dye. the wires are anodizing. however the problem is that the dye wipes off. If the aluminum wasnt anodizing the dye wouldnt sick at all and would wash off.
as for the sealer iam using water and have changed it many times.
thanks!
Old 05-02-2008, 09:07 AM
Z Z is offline
check your anodizing parameters. You could be forming a soft-coat usually caused by high temperature, high concentration, or too low current. Soft coatings can wipe right off after sealed.
Old 05-02-2008, 12:03 PM
destroyer125's Avatar
Sounds like dissolution. You will get excellent dye absorbtion, then after seal, you can whipe the coating off with your finger quite easily. Keep tabs on your anodizing time and temperature of the tank while your doing parts.
Old 05-04-2008, 01:54 AM
sswee's Avatar
Moderator
What power supply is being used and what current density are the parts run at?
SS
  #8 (permalink)
Old 06-14-2008, 09:14 PM
dd016857 is on a distinguished road
I am a newbie too , had this same problem..read somewhere that the temperature has to be below 20 deg C mine was 22 deg C and color would wipe off. As my tank is only a 1 gallon size I use a sealed 1 pint soda pop bottle of water that was frozen the night before and a small glass fish tank thermometer, Place the bottle upright behind the part being ano and use a small plastic paddle to agitate....works like a charm
Closed Thread
one part just wont strip mkriegs Anodizing Questions 2 02-20-2008 01:20 PM
How big a part? charliewolfe Electroplating Questions 2 02-07-2007 11:30 PM
Sax keys wont plate dshook Electroplating Questions 1 06-02-2006 05:06 PM
powder wont take charge? red99ls1ta Powder Coating Questions 4 02-27-2004 07:18 PM
Apply Zincate but flash copper wont stick gevalia Electroplating Questions 5 09-16-2003 07:09 PM
