+ Reply to Thread
Results 1 to 3 of 3
Thread: paint to protect against anodizing fumes
  1. #1
    Join Date
    Jun 2004
    Posts
    104
    Default paint to protect against anodizing fumes
    I'm putting in a larger ventilation fan (previously used a range hood fan). The acid fumes got the best of the old one, but lasted probably a 1-1.5 years anodizing on most weekends only. So I was thinking about the metal casing on this one and was hopping that maybe a good coat of paint on exposed areas might help keep corrosion down and keep it from falling in my ano tank. So does anyone know if there is a particular type of paint that might help best with this theory? I'll probably paint it no matter what and I know I can't keep the fumes out of the motor, but I'd like to take any additional steps I can.
    Justin Martin, VP
    Blackcote
    RR1 Box 116
    Liverpool, PA 17045
    www.blackcote.com
    blackcote@pa.net
    Share with Facebook
  2. #2
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    885
    Default Re: paint to protect against anodizing fumes
    IIRC, there's a diagram in the manual of a fan setup that is out of the air flow of vapors. I can't remember if it's an air jet or fan but either will work. The principle uses air injected into the exhaust piping causing a vacuum to occur at the other end. This draws the fumes into the pipe and expells them.
    I have your setup but have been planning to make the change over to the air vent. In the mean time, an epoxy paint should do the trick.
    Share with Facebook
  3. #3
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,282
    Like Carwiz said, an epoxy paint would be first choice and a good polyurethane would be second.
    SS
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Fumes, Fume suppressants, and Safety stuff
    By destroyer125 in forum Anodizing Questions
    Last Post: 06-21-2006, 12:48 PM
  2. hazards of fumes?
    By Sid03 in forum Anodizing Questions
    Last Post: 02-14-2006, 09:59 AM
  3. Using Clear PC to Protect polishng
    By Mr_sleepy in forum Powder Coating Questions
    Last Post: 03-02-2005, 04:59 PM
  4. Powder Coating bake off fumes?
    By trsick in forum Powder Coating Questions
    Last Post: 07-24-2004, 10:41 PM
  5. Fumes and basic newbie questions
    By PeterBusch in forum Anodizing Questions
    Last Post: 10-05-2003, 09:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
