Is the Mastech HY3020E a good quality power supply for anodizing? Its linear and adjustable 0-30 Volts and 0-20 amps. I guess my real question is will it handle the small stuff accurately? I hate to buy a small PS and then have to buy another one.
Grumple Last edited by Grumple; 05-10-2008 at 11:17 AM. |
The mastech units are pretty good... they're adjustable to within .1 amp, so even smaller parts are OK. BTW, whenevr I need to do 1 small part, I usually include a sacrificial part to spread out the current.
I use three of the Mastech units now, and have only had problems with one over the years... I had to send it back under warranty, but the company I bought it from took care of me. Be sure to ask your seller about warranty. Yes, figure all surfaces in you SA calculations. To convert sq.in to sq.ft., 52.5/144=.363888888sq.ft. If you use 6 amps per sq.ft, that equals 2.18333 amps. Round up to 2.2amps. Turn the volts all the way up and the amps all the way down. Turn on the power supply and slowly ramp up to 2.4 amps. To build 1mil, run for two hours.
Ok, thanks for the info. I am still in the reading/learning stage right at the moment. I need to figure if I can keep the acid type part of the operation outside of my steel workshop so I don't rust out my building.
Thanks, Grumple |
My calculator says 52.5/144 = 0.36458333333333333333333333333333. Did I miss a step for some tweaking allowance??
Grumple |
The VS series....VS-35M or VS-50M or VS-70M.
Astron Corporation
Thanks, Grumple |
| Power supply question | jabe421 | Anodizing Questions | 1 | 05-08-2008 06:55 PM |
| On going power supply question?? | MrPontiac | Electroplating Questions | 9 | 11-14-2007 12:01 PM |
| Power supply follow up question: Attention Fibergeek | Gabourie | Electroplating Questions | 7 | 09-25-2004 08:53 PM |
| Power Supply Question | edwin247 | Anodizing Questions | 5 | 08-30-2004 11:20 AM |
| cheap powdercoating heater/chrome power supply question | dagobert | Electroplating Questions | 0 | 06-01-2004 11:59 AM |
