What is the common size in thickness of lead sheet to use. 1/8" sound about right? When placing one on each side of the tank, is bigger better? Or in a cooler sized tank just get a sheet slightly narrower than the width? Where is the best place to buy this stuff?
Thanks, Grumple |
The lead I get is more like 1/16in. You can get it at roofing supply or non-ferous metals supply.
Bigger won't hurt. I ran a 6in wide strip ever the edge and down the side, accross the bottom and up the other side. I actually slit it down the middle and folded it outward so that when it meets the bottom, it splits out to each side, accross the bottom at the outside corners, then back together again when it goes up the sides.
Thanks. Good info. I guess you connect the leads with alligator clips or solder? As long as the solder joint is not in the liquid? Or do you use a nut and bolt? I hate to ask but I am sure one way is better than another...
Thanks, Grumple |
| plating lead | dlaery | Electroplating Questions | 1 | 02-08-2006 08:07 PM |
| lead cathodes | rclint | Anodizing Questions | 4 | 08-18-2005 09:45 PM |
| Anyone Chrome Lead? | rlchase | Services Offered/Wanted | 2 | 06-19-2004 09:47 AM |
| MSDS sheets for Sealers | rwizinsky | Anodizing Questions | 2 | 12-23-2003 03:26 AM |
| MSDS Sheets | mojobari | Electroplating Questions | 4 | 10-15-2002 11:51 PM |
