I degrease with lacquer thinner first, then heated degreaser. Only dunk the part long enough to pass the water break test.
I don't know about Caswells degreaser being TSP (I doubt it), but it does dull the part, so only degrease long enough to pas WB. Etching the part is only done when the aluminum is old and dirty. Forget about doing that if your parts are well prepared. Neutralizing the acid after ano is something that has proven to cause problems. As long as you rinse well, you don't need it. Spray rinse first, then dunk, then spray again just before going into the dye tank. Pay special attention to the holes, nooks and crannies where acid might be trapped. I wouldn't go lower than 4.5 CD. 6 amps per square foot works well, and is easy to calculate. That's what I suggest. Forget about anodizing to PAR... use the 720 rule calculator. For 6 amps CD, you'll get a full 1 mil in two hours, .75mil in 1-1/2 hours, and .5 in 1 hour. Ano to 1 mil for black and dark colors, .75 for medium colors, and .5 for clear, gold, copper. Lead cathode will last longer, but makes the bath a hazardous waste. A large cathode is better than too small.
Thanks,
That was concise and answered my questions exactly. Do you see any problem with doing 336 sq. in. at 14A in a 4 gallon ano tank with 2 x GP plates. I've got 12 heatsinks I've milled and want to run them in one batch for uniformity. How much will this heat the tank? Would the results be better if I did several batches? I noticed one of the sticky topics shows the proper PH for various color dyes. What do you use to titrate it up and down? Landrum |
I'm no expert but Sodium Hydroxide is what you use to strip anno off aluminum, even a small amount would ruin your entire run and you would have to start over again.
I was wondering about clear ammonia (ammonium hydroxide ) to
raise PH, but I have no idea if it is compatable with the process. Even better would be a buffer solution mixed with the dye when it was packaged. I don't think I care too much since I'm just getting started. I do wonder how much putting a couple of hundred watts into 4 gals of electrolyte for 90mins will raise the temp. Just in case I got out an old water chiller I have meant for a medical laser. It can run down to 4C. I found a Titanium coil made out of 12' of 8mm tubing on Ebay from some guy in Riga Latvia for only 40 bucks. (should cost $300-$600, but I've always heard Ti is cheap and plentiful in the former soviet union.) I'll pump 4C water through that and see what sort of cooling I can get. If it can keep up with the heat input then I might rig up either a 3 way solenoid or 2x 2 way to shunt the flow past the coil or force it through and drive that with a Ranco temp controller to get thermostat controlled cooling. I've used the same chiller to water cool a CCD camera dissapating 40W to a constant 4C hopefully it can do even more. If it can't overcome the input I'll just run it open loop to delay the inevitable. Check out the Ranco controller It's what hobby plating tanks crave. RANCO ETC-111000 Microprocessor Temperature Control: RANC1 Climate Doctors These are pretty cool for the price. I've got that engineer disease that makes me want to resort to massive overkill, this is combined with a love for anything colorful or shiny. Somebody kill me. |
US Specialties does, Caswell doesnt
www.125customs.com - Quality custom anodizing for simple and complicated jobs. |
Sodium Hydroxide won't cause any problems...unless of course you add way to much. I've been using Sodium hydroxide for 3 years now and I'm still using the same black dye solution.
| couple noob questions. | AdrenalineChild | Anodizing Questions | 5 | 08-23-2008 01:31 AM |
| Wiring questions part 2 | 97Dually | Oven Building Forum | 5 | 12-11-2007 08:48 PM |
| Questions about masking and plugging and rectifiers, noob | Paintbalaguy | Anodizing Questions | 5 | 07-18-2005 08:28 PM |
| Coating options on a buffed swing arm | easleysp | Metal Polishing Questions | 3 | 07-08-2005 03:51 AM |
| noob questions | Scottbot | Electroplating Questions | 0 | 05-09-2004 07:07 PM |
