Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 09-06-2008, 01:39 AM
mkriegs is on a distinguished road
Default Blasting cabinet recommendation
I'm getting sick of my current $100 harbor freight blasting cabinet, it never seems to completely remove the grain in the metal, the flow is really inconsistent, it scratches my parts, and it clogs a lot.
Can anyone recommend a blasting cabinet in the $300 range that wouldn't have those problems?
Old 09-06-2008, 03:35 AM
sswee's Avatar
Moderator
Default Re: Blasting cabinet recommendation
No recommendations on a particular cabinet but after using different kinds for years, the better cabinets use a foot feed air valve. They all clog, some more than others depending on media and humidity. I don't know if you can find a good one for $300. If your cabinet size works for you now,an alternative would be to invest in a higher grade gun for the unit.Most of the good cabinets are $800 up and come with a dust vacuum. Good luck on your search.
SS
Old 09-07-2008, 11:25 AM
Yeah, I kind of noticed that, I only see blasting cabinets for <$200 or >$800 and there seems to be basically nothing inbetween those two prices.
Thanks,
Old 09-07-2008, 11:03 PM
Empire03 is on a distinguished road
I had the same problem I just invested in a gun that my friend had gotten for his 1.3k cabinet
Closed Thread
sand blasting cabinet...relocated to tips n tricks section duke Powder Coating Questions 15 12-30-2007 12:28 PM
blasting cabinet iwannapowdercoat2 Powder Coating Questions 6 12-26-2006 11:27 PM
modified cheap blasting cabinet chromeitout Powder Coating Questions 6 06-12-2006 11:30 PM
Converting a syphon media cabinet to a pressure cabinet? trsick Powder Coating Questions 3 03-22-2005 09:41 PM
Sand blasting cabinet=recovery system?? cabrego Powder Coating Questions 4 03-06-2005 05:31 AM
