The HC Version: Volute — Glass-filled Ryton Backplate — Glass-filled Ryton Impeller — Glass-filled Ryton w/ Carbon Bushing Shaft — Ceramic Thrust Washers — Ceramic O-Ring — Viton The SC Version Volute — Glass-filled Polypropylene Housing — Glass-filled Polypropylene Impeller — Glass-filled Polypropylene Shaft — Ceramic Thrust Washers — Ceramic O-Ring - Nitrile (Buna - N) The two differences would be Polypropylene vs Ryton, & Buna-N vs Viton. Now Polypro & Ryton both have excellent resistance against sulfuric acid, along with the Viton o-rings on the HC version. The only thing in either one that is susceptible to damage are the Buna-N o-rings on the SC version. So basically could i not just buy the SC version & swap out brand new high quality Viton o-rings in the impeller housing? For the price difference of the two, it would be well worth the work, unless there is a much bigger problem i am not seeing. Your welcome to state your opinions on this matter, thanks! Chemical Resistance Chart: http://www.lgpc.com/MagDrive/CRC.pdf HC Pumps: http://www.lgpc.com/MagDrive/ByCateg...&CategoryID=19 SC Pumps: http://www.lgpc.com/MagDrive/ByCateg...&CategoryID=18 |
Either will work, Buna N will last a good while with diluted sulfuric acid. If your that worried about it, find the oring Dash # used and buy a viton oring in that size.
www.125customs.com - Quality custom anodizing for simple and complicated jobs. |
I don't know how you feel about ebay, but here's a killer deal:
LITTLE GIANT TE-5-MD-HC MAGNETIC DRIVE PUMP - 115/230V - eBay (item 230288450412 end time Sep-15-08 17:19:16 PDT)
I do things. |
| Using a Mag Drive pump for electrolyte circulation | NeoMoses | Anodizing Questions | 14 | 04-11-2007 02:10 AM |
| Agitation pump, what are you using? | MrPontiac | Electroplating Questions | 2 | 01-20-2007 08:10 PM |
| Eyecandy of my new Pump setup | destroyer125 | Anodizing Questions | 1 | 11-06-2006 11:14 PM |
| Air agitation or pump? | rick201 | Anodizing Questions | 2 | 04-19-2006 02:04 AM |
