+ Reply to Thread
Results 1 to 7 of 7
Thread: pumps
  1. #1
    Join Date
    Jun 2008
    Posts
    57
    Default pumps
    Apparently, the Little Giant pump I am using doesn't like to be "self-priming," where the fluid is drawn up above the level of the surface and into the pump. I don't want to use bulkhead fittings or in any way go through the side of the electrolyte tank below the surface of my bath, for fear of leaks developing.
    Does anybody have a good pump they can recommend for a ~40 gallon tank? I want something tough, that I can leave running most (if not all) of the time.
    Share with Facebook
  2. #2
    Join Date
    Sep 2004
    Posts
    1,236
    Default Re: pumps
    I use the HC Little Giant and added a priming circuit to the plumbing... a vertical T just before the pump inlet that runs up higher than the acid level with a valve at the top. You'll need to have the pump lower than the acid level.
    Then, just take a cup of your electrolyte, open the valve, pour the it down the pipe, close the valve and turn on the pump.
    Once the pump is primed and running. you won't need to prime it again unless the siphon is broken.
    I do things.
    Share with Facebook
  3. #3
    Join Date
    Jun 2008
    Posts
    57
    Default Re: pumps
    That is what I thought, but I have smoke coming out of my pump motor, and Little Giant tells be it is because of the rise. I am using almost exactly the setup you describe. Maybe they just don't want to deal with me?
    Share with Facebook
  4. #4
    Join Date
    Sep 2004
    Posts
    1,236
    Default Re: pumps
    If you smoked the motor, that's a different problem. There is no way that condition would cause a motor to overheat.
    Are you sure you're running at the correct voltage? Mine is a 240v and you wouldn't know it just looking at it.
    I do things.
    Share with Facebook
  5. #5
    Join Date
    Sep 2007
    Location
    Canada
    Posts
    214
    Default Re: pumps
    Running the pump "dry" I read in the manuel can damage it.
    Share with Facebook
  6. #6
    Join Date
    Mar 2008
    Posts
    96
    Default Re: pumps
    The only thing i can think of that would cause smoking out of the motor would be massive friction caused by the impellor or an internal motor problem that is causing it to burn out.
    Share with Facebook
  7. #7
    Join Date
    Sep 2004
    Posts
    1,236
    Default Re: pumps
    They are magnetic drive... it's impossible to "bog" them down, and since there are no seals, running them dry for a few minutes won't hurt. Even if the impeller froze to the housing, it wouldn't affect the motor. If the motor is smoked, return it under warranty.
    I do things.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. ano tank pumps.......
    By Sid03 in forum Anodizing Questions
    Last Post: 03-31-2005, 11:39 AM
  2. output of water pumps.....
    Last Post: 09-16-2004, 10:42 AM
  3. Heaters and Pumps
    By opiesstuff in forum Electroplating Questions
    Last Post: 01-21-2004, 06:30 PM
  4. POWDER COATING WATER PUMPS
    By SHIVERS in forum Powder Coating Questions
    Last Post: 11-02-2003, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
