+ Reply to Thread
Results 1 to 7 of 7
Thread: Handling after ano bath??
  1. Join Date
    Jul 2008
    Posts
    60
    Good morning everyone,
    I have been anodizing for a bit now, and I would like to start adding a bit more art to the parts. One idea that I had, was to stamp the part with a rubber stamp coated in rubber cement. The problem I for see, is how do I support, or handle the part while stamping? Can I touch the part with my bare hand after coming out of the anodizing bath, or can I use a glove or something else?
    What are some thoughts on this?
    Thanks
    Share with Facebook
  2. Join Date
    Sep 2007
    Location
    Canada
    Posts
    214
    Re: Handling after ano bath??
    Wear gloves.
    Share with Facebook
  3. Join Date
    May 2006
    Posts
    104
    Yep, just wear some nitrile gloves. If you know someone who works at a hospital, just have them snag you a box . Automotive and chemical places should also carry them.
    Share with Facebook
  4. Join Date
    Jul 2008
    Posts
    60
    So gloves protect the ano surface from oil from skin? Will latex gloves work?
    What are some other effective ways to apply letters or symbols to fresh ano?
    Thanks for the help so far.
    Share with Facebook
  5. Join Date
    Jun 2008
    Posts
    57
    If you have the means, a small vinyl plotter is a pretty handy way to do graphic masks. I use a Pro-cut CR-630, but if I had it to do over, I might go a little more high end.
    Share with Facebook
  6. Join Date
    Sep 2004
    Posts
    1,235
    Sometimes, even when wearing gloves you may leave a mark. I try not to touch the raw ano at all. I handle the parts by the racking wire, and lay it on a clean rag to work a side.
    I do things.
    Share with Facebook
  7. Join Date
    Jun 2008
    Posts
    57
    True- and I should add too that if anyone uses a vinyl plotter for graphics, I have found that trimming the application tape close to the graphic is a good idea, as well. The adhesive doesn't appear to leave any residue on a part, but it still interferes with dye absorbing into the anodic layer. Handling by the racking is the ideal way to go, and it is worth using a couple of points of contact to make a more stable rack on the part where that is possible.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Help with handling/grounding candy topcoat
    By tjazcustoms in forum Powder Coating Questions
    Last Post: 08-27-2007, 08:40 PM
  2. How much acid in bath?
    By rick201 in forum Anodizing Questions
    Last Post: 05-25-2006, 02:32 PM
  3. anodizing bath
    By jamerson in forum Anodizing Questions
    Last Post: 03-08-2005, 08:28 PM
  4. Copper Bath
    By SDE in forum Electroplating Questions
    Last Post: 12-21-2003, 02:06 PM
  5. Replinishing Ni Bath
    By AustinWillie in forum Electroplating Questions
    Last Post: 12-22-2001, 12:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
