Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Old 11-20-2008, 02:14 PM
donafams is on a distinguished road
Question 25amps & wire ?
i have a 25amp ps and was wondering about wire size that could hold that much current... must be pretty big huh...?
Old 11-20-2008, 03:06 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: 25amps & wire ?
12 ga stranded should be plenty.
I do things.
Old 11-20-2008, 03:54 PM
i would assume that would aslo apply from the tank bar to the part right?
Old 11-20-2008, 07:13 PM
coopduc is an unknown quantity at this point
Agree, although the amperage is high, the voltage is low, so there is really not that much power running through the wire. I'm using 10ga for a 50amp PS and I think that is overkill.
As for the connection to the part, do not use multi strand electrical wire, use either solid rod aluminum or titanium, 1/8" dia is a good practical size.
Old 11-20-2008, 08:59 PM
radmaximus's Avatar
radmaximus is an unknown quantity at this point
Have to respectfully disagree with you coopduc, voltage has very little to do with wire size, unless it comes down to distance (longer wire you start getting voltage drop). Wire size is mainly based on the amperage needed to be carried to it load. You can have a wire with 120v, 208v, 277v, 480v, feeding it and the wire could care less, but overload the amperage on it by a percentage and it will tell you quickly (heat). Besides bigger wire means less resistance per foot of wire.
Allowable conductor ampacities NEC electrical code Table 310-16: Ampacities on insulated conductors 0 - 2000 volts:
14 ga 15amps
12 ga 20
10 ga 30
8 ga 50
6 ga 65
4 ga 85
Wire size is always determined by amperage first not voltage, only adjusted for voltage based on wire lenth (because of voltage drop over long distances, 250 feet of more). And I realize in the amperages and voltages that most of us work in when anodizing it's not a big deal, being an electrician for over 20 years, I hate to see people take chances and undersize wire to save a few pennies. When it could cause serious problems or even injury. Especially when dealing with 120v and higher.
Rad
Tie wire hdway Electroplating Questions 5 03-13-2008 11:24 PM
Wire size? ed_denu Oven Building Forum 10 08-15-2007 09:23 PM
At my wit' end with wire jc88usus Anodizing Questions 5 09-03-2006 06:36 PM
wire spicing Deecoat Oven Building Forum 0 07-27-2006 10:12 PM
How do I wire up a 220 to my box? Hodges Oven Building Forum 3 10-25-2005 11:38 PM
