+ Reply to Thread
Page 2 of 2
FirstFirst 1 2
Results 11 to 15 of 15
Thread: Splash masking questions
  1. #11
    Join Date
    Aug 2008
    Posts
    97
    Default Re: Splash masking questions
    Empire - How long is the acid dip? I tried 30 sec and it had absolutely no effect. I was concerned that longer would start to destroy the cells.
    Share with Facebook
  2. #12
    Join Date
    May 2009
    Posts
    120
    Quote Originally Posted by coopduc View Post
    I tried this technique for the first time tonight per the above instructions..results were aces. dunno if you've sorted it out since coopduc, but I attached results and here's what i did/didn't do::
    didn't wait to dry to apply rubber cement.
    didn't let it cure completely, was still a little tacky, about 10 min. flung it on thinly and hastily. was so paranoid about cells closing on this piece already dipped once (but dye temp was around 125, which i'm sure helped) that i slapped it on right away. lucky maybe.
    i DID soak it in bleach about 3-4 mins, didn't take out all dye and i was worried. an overdip on this would be green. yek. but once i put it in the diluted sulfuric the remaining color leached off within 2-3 minutes and there was no problem in pores taking dye uniformly. happy with the pilot project
    Attached Thumbnails Click image for larger version
    Share with Facebook
  3. #13
    What negative results occur when one:
    1- anodizes the part
    2- applies mask
    3- dyes part
    4- removes mask
    5- clean heavily with laquer thinner
    6- seal
    I did this during some trials and the masking went well, but when I went to dye where I masked, the turquoise dye did not take well at all. It was actually a failure. I am speculating that the masking agent filled up the pores on a microscopic level.
    When doing splash anodizing, is it better to use anodizing mask or actual rubber cement?
    Thanks
    Share with Facebook
  4. #14
    Join Date
    Feb 2009
    Location
    Norfolk, England
    Posts
    196
    if you masked first, then tried to dye once the mask is removed then thats where it goes wrong. you have to think in reverse order. you can only add mask throughout the proccess until you seal.
    so for example: if you want your part black with purple splashes, you ano, then dye purple, mask, bleach, acid dip, bi-carb dip, then into the black. seal, remove mask then seal some more.
    "A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand.
    The Darkside bdk Race Engineering
    Share with Facebook
  5. #15
    Thanks spanky.
    By chance do you or anyone else reading this have an answer for this question:
    Is it better to use anodizing mask from caswell or actual rubber cement? Seems the caswell mask it used for complete masking, but does not specify if it can be used on graphics.
    Thanks!
    Share with Facebook
+ Reply to Thread
Page 2 of 2
FirstFirst 1 2
Thread Information
Users Browsing this Thread
  1. Splash job pic
    By karmaarma in forum Anodizing Questions
    Last Post: 08-24-2008, 10:36 PM
  2. Masking questions
    By Canute7 in forum Anodizing Questions
    Last Post: 05-20-2006, 08:24 PM
  3. Questions about masking and how the powder stays on
    By UnorthodoxCreations in forum Powder Coating Questions
    Last Post: 10-03-2005, 11:45 PM
  4. Questions about masking and plugging and rectifiers, noob
    By Paintbalaguy in forum Anodizing Questions
    Last Post: 07-18-2005, 08:28 PM
  5. Splash anodizing
    By aluminuman2001 in forum Anodizing Questions
    Last Post: 01-02-2004, 03:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
