+ Reply to Thread
Results 1 to 6 of 6
Thread: whats better for stripper?
  1. #1
    Join Date
    Jan 2008
    Posts
    56
    Default whats better for stripper?
    hello everybody just wondering if anyone has used both a lye mixture vs. caswells anno stripper? because right now im using caswells stripper and it just doesnt seem to work very good. appearantly i should not submerse the part for longer than 5 minutes but 5 minutes seems to barely do anything. any suggestions?
    and if i decide to go with a lye mixture what amount of lye to water ratio do i want for best results? thanx.
    Share with Facebook
  2. #2
    Join Date
    Sep 2004
    Posts
    1,235
    Default Re: whats better for stripper?
    Try warming the Caswell stripper to 70F or so.
    Any pure lye drain cleaner will work... make sure it's only white crystals with no metals or funky blue crystals mixed in.
    Lowes sells a 32oz container for 5 or 6 bucks.
    Mix 16oz with 2 gal. water. It will get hot when you mix it, so watch that it's not more than 60F or so when you use it.
    I do things.
    Share with Facebook
  3. #3
    lets say that the mixture is hotter than 60F, how would I lower it?
    Share with Facebook
  4. #4
    Join Date
    Sep 2004
    Posts
    1,235
    Freeze a bottle of water and drop it in.
    I do things.
    Share with Facebook
  5. #5
    if using lye to strip, would it also have to be kept at 70F? and whats the ratio of lye:water?
    (sorry for hijack, check pms)
    Share with Facebook
  6. #6
    Join Date
    Sep 2004
    Posts
    1,235
    I only heat it if it's not working, but don't heat it too much.
    I do things.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Whats the chance
    By mikekozura in forum Oven Building Forum
    Last Post: 03-30-2006, 04:23 PM
  2. whats the best grade
    By craigcraig in forum Powder Coating Questions
    Last Post: 07-08-2004, 04:15 AM
  3. whats the best way to go about two colors on one part?
    By red99ls1ta in forum Powder Coating Questions
    Last Post: 02-24-2004, 10:00 PM
  4. whats up guys, few questions here
    Last Post: 11-12-2003, 06:58 PM
  5. whats the difference?
    By gopedhead in forum Electroplating Questions
    Last Post: 04-07-2002, 12:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
