+ Reply to Thread
Results 1 to 2 of 2
Thread: vinyl masking problem
  1. #1
    Join Date
    Dec 2008
    Location
    Fort Worth,Tx
    Posts
    74
    Default vinyl masking problem
    Hello, I have some 3m vinyl graphics that I had made up just yesterday and well, the release paper on it is exceptionally sticky. The only solution I have found is cut the graphic out around the vinyl, But this is taking allot of time I don't have and second I have a couple graphics that are so detailed that that process would not be done.
    Does anyone know of a release paper or some type of tape that might work that will not leave the ano'd surface sealed from the dye.
    I hope y'all understand what I am trying to explain.
    20 gallon setup. w/ventilation.
    30/20 power supply.
    squirell mixer for agitation.
    home made heat stick for dyes and sealing.
    Fort Worth,Tx
    Share with Facebook
  2. #2
    Join Date
    Dec 2008
    Location
    Fort Worth,Tx
    Posts
    74
    Default Re: vinyl masking problem
    Ok, here is what I tried.
    When the release from the vinyl stuck to the item, I quickly pulled it off.
    Then I tried to clean the release sticky off with Lacquer Thinner, then tried to dye and the part that had the release stuck too, it didn't dye.
    Soooo, I tried to bleach it, then rinsed really good , then stuck it in acid for a couple seconds, then rinsed and still wouldn't take the dye.
    Soooo, I tried one last thing, I heated up the degreaser I use ( Oakite ) and still no luck.
    So, please if you have had this happen before and found a solution, I really need to know.
    Thanks,Clint
    30/20 power supply.
    Fort Worth,Tx
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Masking?? Vinyl Cutter??
    By hjeades in forum Powder Coating Questions
    Last Post: 09-04-2008, 06:01 PM
  2. Vinyl Masking Problem
    By PBInferno in forum Anodizing Questions
    Last Post: 08-11-2007, 11:48 PM
  3. Problem with dyes @ masking
    By LOON in forum Anodizing Questions
    Last Post: 05-12-2007, 07:15 PM
  4. Vinyl Masking
    By Thefool in forum Anodizing Questions
    Last Post: 09-24-2006, 08:04 PM
  5. my first attempt at vinyl masking
    By destroyer125 in forum Anodizing Questions
    Last Post: 05-12-2006, 10:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
