Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Old 03-10-2009, 11:17 AM
Shepard is on a distinguished road
Default Uniform air agitation
For some reason I can't get the air to flow uniformly from the pipe I've drilled and set at the bottom of the tank. I've checked the holes and pipe for obstruction. I'm guessing fewer or smaller holes near the beginning but if someone knows a good pattern it would save me a bit of trial and error. Any suggestions on how to get uniform bubbles throughout the tank are appreciated.
Old 03-10-2009, 05:20 PM
42etus is on a distinguished road
Default Re: Uniform air agitation
It sounds like there isn't enough air volume for the number/size of holes. I would suggest more air volume or fewer holes or smaller holes or any combination. It's kind of hard to make the holes any smaller but you could try covering every other hole with electricians tape and see how that changes things.
Paul
Old 03-10-2009, 10:07 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
My pattern is 1/16 inch hole every 2 inches.
I've noticed there are less bubbles at the opposite end of the air inlet... I'm thinking of adding air to both ends to make it more even.
I do things.
Old 03-10-2009, 11:50 PM
sswee's Avatar
Moderator
I've used 1/16" x 2" same as acid. worked fine.
You may try turning the holes down and see if it helps. Also the level of the pipe will have a slight effect on it.
SS
Old 03-11-2009, 07:46 AM
I appreciate the help. I have a dc motor and I think I'll give agitation a try as well as adding air to both ends of the pipe.
agitation fourkbmx Anodizing Questions 1 10-27-2007 03:08 PM
Agitation hurricaneracing Anodizing Questions 3 11-15-2006 11:40 PM
Agitation ??? hurricaneracing Anodizing Questions 1 08-30-2006 04:53 AM
possible agitation idea??? bigbear Anodizing Questions 5 07-30-2006 02:25 AM
Air agitation or pump? rick201 Anodizing Questions 2 04-19-2006 02:04 AM
