Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Old 03-12-2009, 12:48 PM
babba is on a distinguished road
Default Newbie: Acid to Water Ratio
I've jumped in & bought my first tubs of acid & distiiled water & I've got sooo many qu's to ask.
I got the acid from a UK battery specialist & it's marked as 1/28 kg/l. I've mixed this 1 part acid with 3 parts water, is this right?
First run, I connected the cathode positive & the part negative. My charger tripped & reset continously & there were lots (LOTS) of bubbles, no lasting damage done I hope?
I'm having trouble wiring up the parts I'm trying to anodise & would much prefer to use titanium rod, I can get the rod locally but not wire, will it be OK to mix the rod with (sacrificial) alloy wire?
My thanks in advance, I'm off back to the workshop.
Old 03-12-2009, 02:08 PM
spankey666's Avatar
spankey666 is an unknown quantity at this point
Default Re: Newbie: Acid to Water Ratio
your wiring it the wrong way, + to part
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. " - Douglas Adams
The Darkside bdk Race Engineering
Old 03-12-2009, 02:28 PM
Yeah, only for a couple of minutes though. I was a bit too eager to get my first part anodised.
Old 03-12-2009, 02:54 PM
spankey666's Avatar
has the cathode gone a funny colour?
Old 03-12-2009, 04:22 PM
Not that I've noticed, it's a piece of old lead flashing.
Old 03-12-2009, 09:01 PM
spankey666's Avatar
i suggest you give the lead a thorough clean with a scotch brite pad and rinse in distilled water before you go any further. its always better to be safe than sorry.
Muriatic Acid/Water bath to clean Stainless Bad? ms042180 Electroplating Questions 2 12-23-2006 01:08 PM
What RATIO dry weight of nickel crytals / gallons of water ? ASHENASH Electroplating Questions 1 04-07-2005 12:51 AM
Distilled Water vs DI Water mcgoo49 Other Metal Finishing Questions 0 03-02-2004 09:20 PM
acid ratio when anodizing alum john Anodizing Questions 6 08-03-2003 11:33 AM
Anode size to part ratio mdarr Electroplating Questions 1 07-24-2003 03:20 PM
