I am currently working on a project to set up my own anodizing line. I am anodizing cylindrical aluminium tubes, 80mm in length and 10 mm outer diameter. I have a problem when I anodize the parts, the anodizing process is removing material from the aluminum tubes instead of building up an oxide layer. Approximately 0.3mm is taken from the tube wall. I was wondering what the solution to this problem would be.
The electrolyte I use is 20% sulphuric acid and I use a current of 4.5 amps and 15 volts. Before anodizing I etch the parts in 20% sodium hydroxide and then desmut in phosphoric acid. I have aluminium cathodes and I hang the parts on aluminium welding wire. Also the anodizing tank I use is 100mm x 200mm x 100mm (LxWxH) and i space the cathode/anode as far away as possible.
All the chemicals I use came from a chemistry lab in my college so they should not contain any impurities.
Also my parts dont seem to take the dye I am using. After i seal, and the part has dried the dye has just stuck to the outer surface of the part and falls off when rubbed.
LinkBack URL
About LinkBacks
